What the heck...SpaceX will use this "bouncy castle" for Dragon recovery. How is not known.
I wouldn’t rule that out. What other purpose could that thing serve?It's highly unlikely that the capsule is supposed to land on the thing.
Hmm... As I recall the original "bouncy castle" idea was for fairing recovery. Then I believe I read about it being discussed for second stage recovery. Using it for Dragon would be an interesting development.SpaceX will use this "bouncy castle" for Dragon recovery. How is not known. It's highly unlikely that the capsule is supposed to land on the thing.
If only NASA had agreed to let SpaceX do retropropulsive landings with the Crew Dragon. Aren’t we approaching 20 in a row successful stage landings? It baffles me as to why NASA thinks they are too risky.
Couldn't Dragon use it's engines to steer while being supported by the parachute? For that matter, couldn't they use the retro engines to slow down at a low altitude, then pop the chutes and continue to steer with the engines to minimize unexpected drift? If the engines fail the parachute would still work, if the parachute didn't work, the engines could get it down to the water.
I was under the impression that NASA didn't like the legs and lack of landing system backup, not particularly the use of engine braking.
SpaceX is installing the Crew Access Arm at LC-39A today:
SpaceX readies for installation of LC-39A Crew Access Arm, previews Crew Dragon – NASASpaceFlight.com
Photo credit to NSF member @Cygnusx112
The surface of the water looks like it is directly under the floor of that device ie no bouncy??!!SpaceX will use this "bouncy castle" for Dragon recovery. How is not known. It's highly unlikely that the capsule is supposed to land on the thing.
Crew Access Arm:
Michael Baylor on TwitterGerst: There is potentially a contract change for SpaceX to make DM-2 an operational crew rotation mission.
