e-FTW
New electron smell
That sounds nuts. But not really...According to Hans Koenigsmann, SpaceX is ready and it is just paperwork being shuffled which is causing delays.
A critical launch that the NASA schedule doesn't reflect is the planned Dragon 2 in-flight abort test. Assuming the DM-1 flight happens in January, preliminary reports now peg the abort test for May 2019. So this launch would likely occur just a few weeks before the crewed DM-2 scheduled for June. If a May abort holds up it indicates an additional month or two has been factored into the original turnaround time for the DM-1 capsule. Not sure why, perhaps SpaceX and NASA decided to take more time to examine the first flown Crew Dragon capsule while they finish preparations for DM-2.
Maybe it will speed up the NASA paperwork that Hans alluded to in his recent IAC presentation.Will this impact Crew timing?
Soyuz is currently the only way to get astronauts to and from the ISS. A significant problem is that Soyuz capsules can only stay up for 200 days. MS-9 (which is the capsule with the drilled hole in it) will reach its 200 day limit in December and will have to come back. If it doesn't have the crew on it then the station and crew will have no way to escape an emergency. If it does bring back the crew then the ISS will be abandoned which may be necessary but I doubt anyone will want that to happen.
The current option is to get another Soyuz up and running. Since Soyuz has such a lengthy history, they could probably determine the issue quickly and confirm another launch within the time frame.
Those of us here would probably want them to just send up a Falcon with Dragon 2 but that is unlikely to happen. That said, I wonder if it is possible to send up DM-1 and use that capsule as the emergency capsule. That way the current crew stays on board for the duration.
What is that limit based on?Soyuz is currently the only way to get astronauts to and from the ISS. A significant problem is that Soyuz capsules can only stay up for 200 days. MS-9 (which is the capsule with the drilled hole in it) will reach its 200 day limit in December and will have to come back.
Yes Roscosmos could probably come up with another Soyuz, but that’s not the issue: the issue is figuring out the reason for the mission failure and ensuring it won’t happen again, correct?The current option is to get another Soyuz up and running. Since Soyuz has such a lengthy history, they could probably determine the issue quickly and confirm another launch within the time frame.
I think it very unlikely NASA would do that, it would certainly violate many rules and make them look bad.Those of us here would probably want them to just send up a Falcon with Dragon 2 but that is unlikely to happen. That said, I wonder if it is possible to send up DM-1 and use that capsule as the emergency capsule.
Reading that piece reminds me that the Soyouz has been around for well over half a century. That in itself is amazing.Maybe it will speed up the NASA paperwork that Hans alluded to in his recent IAC presentation.
The next Soyuz mission to the ISS is scheduled for December. It seems this failure will likely delay that.
Soyuz crew lands safely after emergency launch abort – Spaceflight Now
Why (on the rules part)?I think it very unlikely NASA would do that, it would certainly violate many rules and make them look bad.
Informative, perhaps it was time for a reality check. After reading the article I think a SpaceX Dragon 2 or even Boeing Starliner ISS lifeboat scenario isn't very likely. The Starliner parachute system and abort engine issues were already known. The failure of Starliner's pyrotechnic initiators for properly separating the crew and service modules is something I hadn't previously read about.Some updates on the commercial crew program. Brief summary: neither contractor are really ready.
Safety panel says much work left to do before commercial crew ships fly – Spaceflight Now
Another unfamiliar concern is with the SpaceX Crew Dragon parachute system. There's news of "unspecified anomalies" noted in both the Dragon cargo ISS mission return flights and Dragon 2 testing. SpaceX must be working hard to get this fixed and avoid a redesign. Also, they're apparently not out of the woods yet with a redesigned COPV 2.0. Although NASA has qualified the new helium tanks, the testing is ongoing. I recall 7 proving flights were needed prior to DM-2. What's disconcerting are statements made by Don McErlean of the Aerospace Safety Advisory Panel. In part, “These causes of various sorts remain under investigation. There are scientific investigations still ongoing looking for root cause analysis. They are working on improved configurations, but there remain open technical issues that still need to be completed and understood.” Not sure how much impact this will have on DM-2's launch date, but it won't be overlooked.
Probably a fair shot taken at Hans Koenigsmann "We continue to hear these things about certification paperwork, and it’s one of my own personal hot buttons,” McErlean said Thursday. “The work is not paperwork in the sense of blindly filling out forms or writing letters or sending each other memos.”.
From my brief (very brief) experience with government contracting, I'd assign it to CYA.<snip>
ASAP is full of garbage. I don't really know the reasons for their nonsense but it is probably political, money, or prestige.
It's more accurate to say it *started* degrading the day it was produced. And after 200 days in orbit, it approaches a state of degradation where performance may be affected.After 200 days the hydrogen peroxide propellant used for the orbital maneuvering thrusters starts to degrade.
