Commercial Crew Transportation Capability (CCtCap) SpaceX and Boeing Developments
Good point, and one that went unmentioned in that article. Really quite embarrassing for Boeing. I think NASA is cutting them a lot of slack on that test, letting them do it without leaving the ground. But according to the article NASA does not specifically require a true in-flight abort test.
Quote: “While technically just a pad abort test, the certification objective will also validate Starliner’s ability to free itself from the Atlas V at any stage during flight should an abort be needed. However, Boeing will not perform an in-flight abort test as one was not mandated by NASA as part of the Commercial Crew Program.”
How exactly does a pad abort test “validate” that the capability will function properly “at any stage during flight”? That sounds like BS to me. I think NASA just says that because to do a real in-flight abort test is extremely expensive since the entire rocket is thrown away.
By doing the abort test during ascent SpaceX is really going above and beyond NASA’s requirements. I sure how that SpaceX can pull off a successful abort test during Max-Q! That sounds very challenging.
Excellent analysis!
That made me actually LOL. :p
Exactly why I am puzzled: I don't see how a ground test validates that an abort in the max-Q environment would work.
Also, NASA says they'll do an in-flight one for Orion, so... ¯\_(ツ)_/¯
I believe historically no launch program has done an in-flight about test due to cost of the booster. SpaceX definitely has an advantage of this, so they should take full advantage of it. From technical perspective though, I would think that loads from the abort sequence way exceed the aero load that it really doesn't matter if the abort is done on the pad or in flight at Max Q.
How would Orion do an in-flight abort? They sure aren't using a billion dollar SLS rocket for such a thing. Using some other rocket would make the test invalid as far I am concerned.
Reactions: e-FTW
So if a concern was how to heat shield the dragon legs for orbital re-entry heat, how did they solve that problem with the BFR payload (what’s the BFR spaceship called, again?)
BFS (big falcon spaceship) has the heatshield on the bottom like the shuttle. Once it slows, it rotates for vertical landing. So the legs don't interrupt the heat shield.
Check out
http://www.spacex.com/sites/spacex/files/making_life_multiplanetary-2017.pdf
Last slide has link to the simulation video.
This does show NASA is guilty of 'guilding the lily' in important matters. It's puzzled me why, if NASA loves what SpaceX is doing so much,
that they seem to favor Boeing in ways designed to not fall behind SpaceX. In this case they appear to be short changing safety of astronauts on the maiden Starliner flight, at the same time as they keep tightening the safety requirements far beyond that of any spacecraft they've ever certified.
Naturally that can be explained at least partly by political pressure from the many states that suck at Boeings teet. However it occurs to me that a second reason is there is no guarantee that SpaceX inflight abort test and launch with no crew might not fail. That is a real possibility.
If they can't manage to keep Boeing moving along on the same timeline, then if SpaceX has a RUD, NASA is dependent for another year or two on Russia continuing to fly astronauts to ISS. Give how relations have deteriorated, that would put ISS and all NASA admin careers in dire jeopardy.
From Starliner update article:
"NASA has updated its Commercial Crew Transportation Capability (CCtCap) contract with Boeing to allow for the possibility of the CFT mission adding an additional crew member and extending the flight from 14 days to six months."
I would be pretty incredulous if ISS is not all set to accommodate both Dragon and Starliner capsules at the same time,
but I'll ask anyway. If not, then if the extension to 6 months gets approved and Boeing gets that crew to ISS first, SpaceX would be blocked from delivering a crew for half a year.
Reactions: Grendal
The first IDA (International Docking Patter) was lost with CRS-7. The second IDA was installed in 2016 (first on ISS). They built a third to give two ports on ISS, it should be launched on CRS-16 on 16 November 2018.
ISS Docking Module Relocates to Establish Second Commercial Crew Docking Port – Spaceflight101
IDA 1, 2, 3
SpaceX CRS-16 - Wikipedia
From the Ars Technica article, "In some abort scenarios the company has simulated, the Starliner spacecraft has tumbled. Boeing hopes to put these concerns to rest with a pad abort flight test, which should occur soon." Okay, so it's probably a great idea to only have SpaceX's Dragon 2 spacecraft, the one that doesn't tumble in abort scenarios, do the actual in-flight abort test. :confused:
Reactions: Cosmacelf
SpaceX Crew Dragon ship in anechoic chamber for EMI testing before being sent to @NASA Plum Brook vacuum chamber
