Comparison between 2 Model X 85kWh cars, with a single and a dual motor: 5 Questions?
Discussion in 'Model X' started by Benz, Jan 31, 2013.
Tags:
  1. Benz
    Benz Active Member
    Netherlands
    Suppose we have the following situation.
    There is a 1,000 km long straight road of good quality (specially good for fast driving, like a race track) with no hills, or stoplights or any other obstructions. The weather is fine and there is no traffic at all. And we have two Tesla Model X cars (both have a 100% full charged 85 kWh battery), 1 is red and has 1 motor, and the other is blue and has a dual motor. Both start at the same time and drive (side by side) slowly (say in 40 seconds) up to a speed of 200 km/hr, and the cruise control keeps them at that speed until the battery will have gone fully empty (0%). There are no pit-stops or anything. Both cars have only the driver sitting in them. Both cars are equally equiped, and have the same tyres, etc. These Model X cars are not the Performance or the Signature models, they are just the standard production car with the largest battery pack available (85kWh).
    My questions are:
    1) Does the single motor of the red Tesla Model X have to work "harder", compared to the two separate motors of the blue Tesla Model X? Regarding that both cars are driving at the same speed of 200 km/hr.
    2) Do the two separate motors in the blue Tesla Model X have to work equally "hard"? Or is there a difference between the two separate motors?
    3) Do the two separate motors in the blue Tesla Model X always work together from the start, or will the second motor be turned on only at a certain speed?
    4) Will the total distance of the journey of both cars be the same (when the battery finally is empty), or will 1 of the cars stop earlier than the other?
    5) Can we say something about how long the total distance (separately) of the journey of both cars will be in km?
  2. AnOutsider
    AnOutsider S532 # XS27
    These are good questions, and while I don't have the answers, I do remember it being said the dual motors were supposed to make it the "best handling car on the road". Regardless of the validity of that, if it's mainly for handling, I couldn't see the additional motor having to do much work.
    As for the additional motor helping out, maybe that's the case, but then wouldn't you use more energy on the second motor anyway, thus nullifying any efficiency gained by having a "helping hand"? I tend to think the second motor will help in handling and performance, and likely lower efficiency (AWD cars tend to get less MPG than RWD or FWD).
    Someone else with more knowledge can likely enlighten us both, though.
  3. arg
    arg Supporting Member
    Cambridge, UK
    #3 arg, Jan 31, 2013
    Yes. Like any 4-wheel-drive, you have the extra work of spinning the drive shafts/differential/gearbox that are connected to the front wheels on the blue car that are just not present at all on the red car. And the blue car is heavier. Both effects are small, but non-zero. In your artificial case where the road is infinitely long with no stops or gradients, then the transmission loss is more significant.
    So, the total amount of power to be supplied by the two motors in the blue car is (slightly) more than that in the red car.
    Absolutely not. I would speculate that the motors will be of different sizes/power ratings (as the rear will be the same as the Model S, and you don't have enough power from the battery to run two of that size).
    However, even if they two motors were identical, there is no need to deliver the same power to both. The control systems could do anything from a 50:50 power split to leaving one motor spinning undriven and putting all of the power to the other. Under acceleration, this significantly affects the handling of the car and it will be interesting to see what Tesla do - they've got much more freedom than a comparable 4WD ICE car. For steady-state cruise in your example, they will presumably use whatever split uses least energy - and it's hard to say from first principles what that is.
    There is a slight possibility that at some speeds using two motors at half the power is more efficient than one motor working very hard, maybe even enough to offset the losses from the transmission, but I wouldn't bet on it.
    No. If anything, the other way around: at low speeds, performance is limited by traction at the tyres and the maximum current limit of the motor, rather than the available power: this is where two motors are a big benefit.
    Almost certainly different, and in your artificial test I would expect the red (RWD) car to go further than the blue (4WD). Probably not a big difference - maybe similar to the difference between 19" wheels/standard tyres and 21" wheels/performance tyres that is seen on Model S.
    But in real use there is another difference: the blue car will be able to regen on all four wheels. This doesn't help at all in your test, and maybe doesn't help that much in real use as the regen is often limited by the battery's ability to accept the charge rather than by traction - but it may allow a more aggressive regen profile than in the RWD car (where the regen control has to be careful not to skid the wheels).
    Not much. At such a high speed, it won't be very large (model X aerodymamics presumably worse than Model S). Maybe a few percent less for the blue car.
    Tesla's graphs for the Model S only go to 80mph/130km/h (for the graph in the blog post with axes) or 115mph/185km/h (for the one on the new calculator page with no axes) so it's hard to extrapolate as far as 200km/h, but for the Model S it must be around 150km. So a bit less than that for the Model X.
    Also in reality, the cruise control won't let you go at full speed to 0 capacity: power limiting and warnings will cut in well before that.
    But an interesting set of questions!
  4. Benz
    Benz Active Member
    Netherlands
    Wow, I am glad to have put these questions on paper. Because I sure do like to hear the opinion of somebody who knows a bit (or even a lot) more about automotive than I do. So, thanks for the reply. And I sure hope to get more replies in this thread as time goes by.
    I noticed that I have made a mistake regarding the top speed of 200 km/hr in the situation that I have described. A top speed of 160 km/hr would be more likely and real.
    Has Tesla Motors already unveiled what the top speed is of a Tesla Model X with a 85 kWh battery pack, and with a single (standard) electric motor between the rear wheels? Is it even possible to drive this car at a speed of 200 km/hr? That just might not be the case with this Model X car, I am afraid?
    The top speed of the (standard production) Model S is 200 km/hr.
    The top speed of the Performance Model S is 212 km/hr.
    The Model S really has got a very low drag figure (0.24 I believe). The shape of the Model X is obviously not as aerodynamic as the Model S. That is for sure, so that would mean that the top speed that I have used in the situation that I have described is too optimistic and certainly not correct. That must be the conclusion now. Therefore I shall have to change that. I think that a top speed of 160 km/hr should be very well possible with the standard production Model X with a 85 kWh battery pack, and with a single (standard) electric motor between the rear wheels. Do you agree on this?
  5. widodh
    widodh Model S 85kWh
    Middelburg, The Netherlands
    160km/h won't be a problem I guess, but do keep in mind that speed kills range. That's just the laws of physics kicking in.
    I agree with what has been said above. One motor will probably be more efficient since you have a drive-train less and the car will weigh less.
    The one with dual motors might be at 200km/h (or whatever) in a shorter time, but it will use slightly more.
  6. Benz
    Benz Active Member
    Netherlands
    I should have been more clear on the modification of the initial situation.
    What I actually wanted to say is that both of the cars are driven at the same speed (in order to keep the test as simple as possible), which has been decreased to 160 km/hr (to have a more realistic situation).
  7. NigelM
    NigelM Recovering Member
    Sarasota, FL
    Now that's an interesting thought!
  8. widodh
    That doesn't change the answer.
    I think the RWD drive car will get a slightly better range. This is because there is less mechanical parts turning around in the car.
  9. clea
    clea Member
    Laval, Quebec
    but what if there is a different gear ratio between the front and rear? would that not allow better power consumption at higher speeds if they changed the drive used for cruising for example?
  10. Benz
    Benz Active Member
    Netherlands
    If we take a look at the Tesla Motors website.
    On the Model X page is written:
    "Model X is offered with optional Dual Motor All-Wheel Drive. The second motor enables more than all-weather, all-road capabilities: it increases torque by 50%."
    About the Dual Motor: "Are both motors identical and equally powerful (rear and front)?
    If they really would be identical and equally powerful, shouldn't the increase of torque be by 100?
    And if the increase of torque is really 50%, then does it mean that the second motor (front) is half as powerful as the first motor (rear)?
    Does this make sense to anybody?
  11. arg
    Cambridge, UK
    I was wondering about that too.
    I don't think it would help all that much with the energy efficiency over normal speeds, as this sort of motor has a fairly flat efficiency curve. Possibly it might at very high speeds (like the 200km/h originally suggested here).
    But another advantage of a second motor with a higher gear ratio would be to improve the acceleration at high speeds - where the existing motor gets voltage-limited and power reduces with increasing speed. This is where the ModelS (and Roadster) lose out to ICE cars in performance tests - having been very fast 0-60, the ICE catches up later due to having a gearbox. If ModelX's second motor is geared higher, the second motor would then have less torque at lower speed (but that doesn't matter much as the first motor can use everything the battery has to offer), while at higher speed the first motor is getting voltage limited but the second motor isn't.
    There are probably other snags that count against this, but at first sight it seems like it offers most of the benefits of a 2-speed transmission without much disadvantage.
    Unfortunately, that quote doesn't tell us very much. 50% more torque at what speed? At different speeds, the limiting factors are different (motor vs battery vs electronics vs cooling).
    My original guess was that the Model X motor would be smaller. 50% smaller would be reasonable.
    But maybe they can't justify developing a new motor just for the 4WD cars and want to re-use the existing one. Improvement could be limited to 50% by the batteries.
    Or it could be the same motor with a different gear ratio (as above): only 50% more torque off the line, but also more torque at high speeds.
    It's hard for us arm-chair designers to guess what Tesla are going to come up with - but the more you think about it, the more it becomes clear that there is scope for them to do lots of interesting things.
  12. jerry33
    Texas
    Presumably with dual motors, the limitation will be what you can draw out of the battery without additional battery degradation. That's probably where the 50% more comes from (rather than 100% more).
  13. efxjim
    efxjim Member
    Glendale, CA
    Talked to an unnamed Tesla engineer who suggested that different ratios might be used to improve efficiency. Stop and go urban driving would use one motor more and freeway driving the other. Both would be used for fast acceleration and slippery surface needs.
  14. stopcrazypp
    stopcrazypp Well-Known Member
    In terms of the battery, by the time the Model X comes out, at most they can add about 30% more battery capacity (using 4000mAh cells which are scheduled to start production sometime this year, 4000/3100 = 1.3x) without increasing the pack size.
    Given they are pushing the 40kWh 1.2x harder than the P85 (175kW/40kWh = 4.375C, 310kW/85kWh = 3.647C), that works out to 1.3x1.2 = 1.56x more available power for a pack using 4000mAh cells. That clearly explains where the 50% more comes from.
  15. scottf200
    scottf200 Active Member
    Chicagoland ModelX S603
    #15 scottf200, Feb 3, 2013
    This video indicate they would be used for different purposes as well.
    Tesla Model X demonstration - YouTube
