Comparison Model S, Model X
Discussion in 'Model X' started by LST, Feb 10, 2012.
Tags:
  1. LST
    LST Senior Member
    Switzerland
    An urgent question to all who attended the unveiling: Can you share your impressions on the eventual comparative advantage between Model S and X ? Leaving aside the design aspects and add/rwd theme. Is it that roomier ? Can you fold and stack away the seats? Would it be possible to go on a winter holiday (skis, snowboards, hockey gear etc.) with a family of 5 ?
    Thank you for sharing
  2. WhiteKnight
    WhiteKnight _____ P85 #549 _____ Sig Red / Sig White
    Atlanta
    Model X is quite a bit taller than Model S. You can fit considerably more in the Model X but if you 've got skis (and 5 people) you still need a roof rack. Which I heard was an option on Model X (not sure how it works with falcon doors).
  3. Bearman
    Bearman Member
    Sweden
    About the roof rack, I understand it is useful to some people and difficult to implement with the falcon doors. I used to drive and haul my skis around Europe when i went on skiing vacations but then started to take flights to destination combined with local transportation. Nowadays i just rent skis on location for the week or two instead of buying new ones every two years.
  4. felixtb
    felixtb RsEU502,Sp+14274,XpEUSig4
    Lausanne, CH
    I asked the engineer driving the X when I got my ride about the roof rack question and his answer was they have planed for it with a ingenious idea that they were not going to reveal quite yet but he basically said not to worry it will be there even with falcon doors..... we'll just have to wait and see
  5. Hasse
    Hasse Member
    Aland Islands
    I guess you could fit a split roof rack on top of the falcon door and tilt the cargo (if we are talking about skis) when opening the doors?
  6. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    To the OP -- although I wasn't there, it's clear that the Model X will have a lot more luggage space, with the third row folded down, than the Model S will (with the second row up). The X's frunk is much larger, and the X's rear space (with the third row down) is both deeper and longer than the S's. Snowboards and hockey gear will fit inside. Alpine skis, uncertain. The AWD availability should make the X a better snow car.
    The roof rack seems, at best, challenging and complex.
  7. NigelM
    NigelM Recovering Member
    Northern Virginia
    :confused: Cargo sandwich?
  8. Bearman
    Bearman Member
    Sweden
    I would use half the cars width for a roof rack and disable one of the doors (you can access the rear through one back door) when i was using the rack.
  9. donauker
    donauker Member
    Use half and have it on a motorized track to shift it from one side to the other for one door at a time? :eek:
  10. NigelM
    Northern Virginia
    And just have the rack attached on one side also?
  11. Bearman
    Bearman Member
    Sweden
    Just have the roof attachments on each side of the falcon doors, the ski box only covers half the cars width so one door opens freely.
  12. PV4EV
    PV4EV Supporting Member
    Area 51(a) / UK
    ... or fit a roof rack on a Model S ?
  13. vfx
    vfx Well-Known Member
    CA CA
    They showed a still with all the seat folded flat. Elon's quote was that you could almost fit a queen sized mattress in there.
    ____________________
    If this X is rocking...
  14. bonnie
    bonnie I play a nice person on twitter.
    Columbia River Gorge
    Not to mention that the screen behind him said 'What else can you do in a Model X?' when he made the queen-sized bed comment.
  15. NigelM
    Northern Virginia
    Split seats? One side up, one flat down?
  16. AnOutsider
    AnOutsider S532 # XS27
    This post needs a "like" button :biggrin:
  17. ckessel
    ckessel Active Member
    The Model XXX comes with a queen bed standard?
  18. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    If so order the privacy glass please!
  19. vfx
    CA CA
    That might beat you driving with your top off.
  20. doug
    doug Administrator / Head Moderator
    SF Bay Area
    Maybe they're gonna use the idea I suggested here.
