  • The final cut of TMC Podcast #29 is available now with topics time-stamped. We discussed the Tesla Cybertruck's expected 1 MW Ultra-Fast Charging capability, the Tesla Semi Delivery Event, the coming Model 3 refresh (project "Highland"), and more. You can watch it now on YouTube.
Compatible Garage Door Openers?
Rachmaninov
227
155
NJ
I’m looking to buy two new garage door openers and wanted to make sure they will be compatible with the Tesla system.
Can anyone suggest a suitable high quality brand/model?
Any brands / models that have known issues with Tesla systems?
Thanks
Edit - I’m also trying to make sure it will work with the Tesla summon feature (when that function is perfected)
Wennfred
3,113
2,206
San Diego
I use the marantec synergy 270, high quality and ultra quiet belt driven. The 370 version comes with the battery back up so if you lose power to the house, it will still open. German made and solid. The only issue I had was I had to remove the LED light as it caused issues with the HomeLink, I have other lights in the garage so that’s was ok. I wanted ultra quiet and that’s why I went that route. My 10 year old Genie was way too loud. As far as it being reliable with Homelink 99% of the time, closes when you leave 30 feet away and opens when you get close to the door on the way back.
Fred
Wennfred
3,113
2,206
San Diego
This is the style of LED light that comes with the Marantec that I removed, check the other brands when you look to see if it has this type of LED waffler light. If your opener is having issues programming, remove the light and see if that helps. Most newer openers come with these powerful LED’s
Rockster
3,025
4,710
McKinney, TX
I went with a LiftMaster wall mounted opener instead of a ceiling mounted opener like I've used for decades. I'll never go back to a ceiling mounted opener. It makes so much more sense to attach the opener to the wall next to the door than to put it 10 feet away and then need to use a chain or a screw shaft to connect it to the door. Plus, my master bedroom is above the garage and now the opener doesn't cause the master bedroom to rumble like it did before.
Reactions: Wennfred
Wennfred
3,113
2,206
San Diego
I went with a LiftMaster wall mounted opener instead of a ceiling mounted opener like I've used for decades. I'll never got back to a ceiling mounted opener. It makes so much more sense to attach the opener to the wall next to the door than to put it 10 feet away and then need to use a chain or a screw shaft to connect it to the door. Plus, my master bedroom is above the garage and now the opener doesn't cause the master bedroom to rumble like it did before.
Awesome! I’ve never seen a wall mount unit, thanks for posting.
Fred
