I am looking at an extensive repair - basically a new roof due to a seal that may not even impact whether or not moisture enters the car. Tesla advised they would pay to have the roof recovered in Xpel.
What would you do?
Detail:
I have a loose rubber seal that will require the removal of the roof, windshield and lift gate in order for the correction to be made. This is the solution according to Tesla and their service manual.
This seal is located on the passenger side of the car. The gap between the roof panel and the panel above the rear passenger door in this area appears to be nearly twice as wide as the same area on the driver's side. It appears to widen from front to back since the gap on each side of the car near the front windshield is the same. The extra panel spacing on the passenger side seems to have lead to the failing of the seal.
The complete removal of the roof along with the front glass and rear lift gate was the option Tesla suggested after their attempt to reapply adhesive immediately failed, even before I left the service center.
This was my fifth trip to the SC in roughly four months since purchase. Fit and finish issues and a broken A/C were the cause of most service appointments. This most recent visit was due to a loose passenger door seal and the aforementioned roof seal.
Video of loose seal:
This is the passenger side which shows the loose seal:
This is on the driver's side - how the seal should fit:
What would you do?
Detail:
