I've got a "sprawling" single story house with a 400A feed and multiple sub-panels scattered around. We converted it to heat pumps for air and water a few years ago and have a large solar array connected to a 200A sub-panel on the far side of the house from the main feed. My main concern is that long power cuts tend to occur during winter storms, which is when I most want to keep the house warm and need a lot of heat pump power, and I have electric auxiliary heat, not gas, so it pulls a lot of power on very cold nights. The house is not easy to keep warm, high ceilings and solid concrete walls.
After well over a year, Tesla is finally starting to move on powerwall installation, but their inability to provide any transparency or discussion of what's going on or how they plan to install isn't inspiring confidence.
We've got 6 powerwalls in the order, we already have 30KW of solar, and eGauges on the main circuits and sub-panels so we can see where the power is going.
The powerwalls will tap into the 400A main panel, as we need to isolate and backup things on both of the 200A sides of the panel.
I have a bunch of questions that I'm hoping people here can help with.
I'm not sure how the gateway switching works for 400A? Are there two gateways working together?
How can I automatically switch off individual circuits during a power cut, to make the batteries last? I've seen some wifi enabled individual breakers that look promising, but I'm not sure how to tie them in to the gateway and automate turning off things like pool pump circuits.
Thanks for any ideas
Adrian
Adrian
