I have one strange issue with the USB playback that I haven't managed to find anywhere:
I have a USB drive in the car loaded with a small amount of music(~4GB). This worked and loaded fine when I got the car(December 2016) until a few months ago when the "USB" section in the music player disappeared.
I have a USB drive in the car loaded with a small amount of music(~4GB). This worked and loaded fine when I got the car(December 2016) until a few months ago when the "USB" section in the music player disappeared. Finally, this last weekend, I took the time to bring the USB upstairs to look it over with my computer to see if I could find anything wrong. Everything is still there and looks fine. The drive is formatted FAT32 and the music is all in mp3 format. I tried rearranging it with Testap's music organization app to see if that would help, and added some cover art while I was at it with MediaMonkey. I took the drive back down and plugged it in and still no dice. I suppose it's possible they broke/removed support for some USB device drivers during some update along the way, but I haven't seen any widespread reports of things like this here.
not sure if this is your problem, but there is a longstanding media player bug (one of many bugs) where the "wrong" source or no source is selected when you get back in the car. e.g. you're playing USB music, then park the car but when you get back in, instead of resuming what you were playing before on USB either a completely different source (e.g. radio) is selected, or NO audio source at all is selected.
I've noticed that sometimes the USB tab even goes missing in such case that no source is selected. If I then select, for example, the Streaming Slacker tab, then the USB tab will magically reappear. No long time-consuming rescanning of the USB device happens in this case (my USB drive is 64GB), it just reappears and can be reselected for playback immediately. The media player still does this, I just saw it again this week - I'm currently on 2018.2 0eddd23
Hmmm I've tried both front USB ports, but might try the back ones. I guess either way, I'll probably be contacting service.Bad port perhaps? On 50.3 and everything works as with earlier releases.
Don't bother with the back ones. Media player cannot see those.Hmmm I've tried both front USB ports, but might try the back ones. I guess either way, I'll probably be contacting service.
What kind of device are you using? (I think one of the firmware updates removed support for some, if not all, HDDs.)
This may seem obvious but in the immortal words of the IT Crowd, "Hello IT, have you tried turning it off and on again?".I have one strange issue with the USB playback that I haven't managed to find anywhere:
In other words, did you reboot the car?
Have you tried replacing the USB flash drive with a different one?
Have you tried to measure the USB port to see if it is outputting 5V?I’ve tried, but the only other ones I have were ones that weren’t detected before the problem. They, of course, still aren’t after either.
If you're unsure how to measure you can always buy a device to do it for you.I have not(not entirely sure how to...) but my phone charges using the port, which, I believe, requires something at least very close to 5V.
