BertL
In this case, it wasn't the next alpha one. Odd to be sure!Was it by chance the next song alphabetically? I have seen this before. Once it plays a song it decides the next one, no matter what, should be the next alpha song.
Any thoughts on if or could be used for FLAC?I've made an initial release of TeslaTags on GitHub here: Jehoel/TeslaTags
Yes. I have a combination of FLAC and MP3 files and the car sorts them by artist and album tags in the same way. There's no visible distinction between these types in the media player, except for one thing: it's unable to remember its place in the middle of a FLAC file when you pause and return to the car later. It does, however, know how to keep its place in a MP3 file. That's one of many bugs previously discussed in this thread.I can add FLAC support quite easily, sure.
I don't use FLAC myself - but does the car's media library sort them the same way as MP3s then?
Be aware that FLAC files do not use ID3 tags as MP3 files do; they have their own native tag format, called a "Vorbis comment."
I've thought about writing my own FLAC tagger too but so far, the command-line 'metaflac' tool has been sufficient for adding cover art. The 'Tag' app (by Stephen Booth, who also wrote 'Max') works well for editing artist and album data on a Mac.
Thanks. I will give it a try next week.I've published my changes with FLAC support and the ability to reset track-numbers, album-art and remove APE tags all from the GUI:
You can also change the name of the top level folder to force it to reindex the files too.UPDATE: I rearranged folders to trigger a re-scan and now all songs are indexed correctly. Weird.
FWIW I think it’s great you’re developing a new set of workarounds. Absolutely great! Your posts here are similar to how I initially found Tesla Tunes in its early days in another now old and almost forgotten thread, which helped me get started on this adventure trying to understand MP USB and making MP work a little better from my POV.I've fixed more bugs and added more features, here's release 4: github.com/Jehoel/TeslaTags/releases/tag/release-4
That being said, IMHO as time progresses with your new Windows-based tool, it may be worth considering creating a unique thread for folks that want to explore your tool and it’s new capabilities, and as a way for them to suggest features and discuss its development beyond this thread that has been focused since it’s inception primarily on identifying MP problems and their more generic workarounds. I’m personally good either way... simply throwing out a suggestion for consideration as interest increases in your development effort to prevent this thread one day perhaps straying too far off-topic and the Mods possibly intervening one day. TMC Mods don’t seem particularly rigid as other forums I’ve been a part of, and even helped moderate myself in the past, but I throw out the thought for consideration as time progresses... I’m good either way, as most of us reading and contributing to this thread want MP USB to be so much more than it is, so I appreciate what each of us do trying to make MP more than Tesla elects to make of it. It’s simply a thought for consideration as your tool becomes more mainstream and interest grows, so more people may find the good stuff you are producing. While I’m primarily a Mac kinda guy for the last several years, and avoid using my PC Windows laptop except for a single non-macOS application it runs, I’m always interested watching what you’re able to accomplish. Good luck!
Congrats on your M3. Unsure exactly to what degree M3 USB Player is the same or different than my MS (we do know M3 is running at least some amount of new underlying code, and I suspect M3 has more physical memory or at least uses it differently than a MS/MX does) but in case it's helpful:First off, thanks for the Tag Tool. I am a new M3 owner (as in this week) and have a large music library that is carefully tagged. I added about 20k songs (MP3) to a 256gb USB stick (SanDisk Cruzer Glide 3 if that helps) and was disappointed to see the clear tagging deficiencies. I'll try TeslaTags as it looks like that should solve these issues.
I also am having an issue where the car is indexing the drive every time I re-start the car. This takes 10+ minutes and is clearly not acceptable. It sounds like i'm not the only one with this issue but I would sincerely appreciate any insight/guidance as to how to best address it?
Thanks!
I have a lot of Various Artists albums like "Concert for George" that are an absolute PITA to retag for the Tesla format. I tried Tesla Tunes, but it is designed for converting iTunes playlists, which I don't use. I need a program that retags existing MP3 and FLAC files from folders in a library. If you ever write a Mac version of the tagger, that would be a godsend.I've fixed more bugs and added more features, here's release 4: github.com/Jehoel/TeslaTags/releases/tag/release-4
It's all about Tesla's poor error recovery routines.How the USB drive could sabotage the rest of the system is still a head-scratcher to me.
What OS are you using: Linux, Windows, or macOS?I have a lot of Various Artists albums like "Concert for George" that are an absolute PITA to retag for the Tesla format. I tried Tesla Tunes, but it is designed for converting iTunes playlists, which I don't use. I need a program that retags existing MP3 and FLAC files from folders in a library. If you ever write a Mac version of the tagger, that would be a godsend.
