I offer that you are wrong.
As anticipated, you consider it "
Hullablloo".
Tesla *did* participate in the plug-in charging standards. Tesla's EVSE conform to the J1772 standards, with the only exception being the connector; and Tesla explained why they did so - the J1772 connector is a horrible design - minimally keyed, easily damaged, and difficult to plug in. Tesla was shooting for the ease-of-use and customer experience while the rest of the group were playing with their engineering calculators.
Participate in and comply with are two different things.
Supercharger using the same EVSE output connector is the issue; as there has yet to be a EV public/national standard for a single electrical connector/contacts for two different voltage applications.
Tesla uses its engineering knowledge as the manufacture and proprietary connector configuration to claim the Supercharger and HPWC are designed to applicable safety standard.
I am aware Tesla also has an NRTL do a "Field Inspection" where required that is available to the jurisdiction for each Supercharger site approved for operation. see attachments
Now, Tesla isn't in the business of making J1772 EVSE for other manufacturers - it is in the business of supporting its own cars. This is why you'll never see an official Tesla adapter for a J1772 application. But Tesla's pricing invites a lot of repurposing - just as a cheap screwdriver makes a great mini-pry-bar in a pinch - so that you don't have a buy a specific tool. At some point we can expect that Tesla (or a third party manufacturer) will sell the TSL02 car inlet, when parts are made more freely available. That's about all you're going to get from Tesla.
In the meantime, you're going to have enterprising people build these types of things in relatively low-volume for a need/desire, and that's okay. In three years, the charging landscape is going to look very, very different.
Agreed, however there are always those ignorant of national standards and requirements that cover the electrical equipment and the laws they break.
To address another point: the superchargers do not apply 400VDC @ 300A to the charge port before they require intelligent communication and vehicle validation to do so - it's a critical interlock and is full of safety checks because even Model S would blow up if the DC power were added to the Tesla's pins without the car's contactors. The car communicates with the superchargers, the superchargers tell the car to engage the direct battery contactors, the superchargers validate that they're seeing DC voltage from the battery pack, and *then* they engage the charging power..
Except - interlocks are a secondary safety device and are not considered a primary safety device (UL standard engineering requirement) as the connector configuration and keying is required for primary physical separation between the various standards (SAE, CHAdeMO) and non-standard Tesla EVSE interconnection.
With the Tesla supercharger and HPWC using a proprietary the EVSE connector the EV onboard system and EVSE communicate to make an engineered safety system.
Therefore, Tesla will never approve an "Tesla/J1772" adapter so all that remains is for enterprising people to hack the Tesla proprietary communication protocol and switch the 400Vdc on to a non-Tesla EV J1772 connector. I anticipate the same of a Tesla/CHAdeMo connector.
Finally, none of the NRTL/OSHA stuff matters here. You're not going to find OSHA following an iMIEV around to make sure that the driver uses only listed equipment where applicable. And I don't expect to see the parking lot guards at Tesla asking to see your UL certification mark on your UMC before you're allowed to plug in at their 14-50's. If you ask most organizations' health & safety team whether their top ten concerns include someone plugging in non-listed equipment to a receptacle, you'll be laughed out of the building. It should be noted that at thousands of workspaces every single day, you'll find non-listed equipment plugged in to outlets to charge phones, or operate mini fish-aquariums, or whatever. Even *if* something were to happen. the investigation would look to see who attached the faulty equipment - *not* whether or not something was listed or not. The investigators are not going to ask to see evidence of a workplace NRTL listing checkpoint so that no contraband appliances are brought into the workplace, so can we get past that?.
You are correct no one cares about the EV owner, but the facility operator/property owner cannot turn a blind-eye to misuse of equipment installed on their site as they will always be held responsible for its use/misuse.
I was the AHJ (senior authority) where NRTL/OSHA regulations applied to installed equipment. This stuff maters when thing go wrong during unauthorized equipment use with fines, citations and facility coordinator disciplinary actions by their employer and with negligence people can be held personally liable with civil or criminal charges.
As even a custom fabricated 110/240Vac extension cords must be made from listed/approved parts; appropriate for that purpose, i.e. listed cord end devices only.
OSHA requires the employer and business operator will have a Fire Martial that will expect the facility to be supervised based on all equipment on site as ignorance is not an excuse for non-compliance to manufacture instruction and equipment installation code/safety requirement.
As I mentioned previously, my biggest concern is related to the pin-and-sleeve connectors used in the TSL02 connection. We've already seen evidence of single cars expanding the HPWC connector's sleeves over time - my HPWC cable has been replaced twice; thorough cleaning did not reduce the heat; and replacement of the cable alone eliminated the heat problem, so it was a matter of a high-resistance connection and I suspect deformation of the sleeves. If the inlet and connector were reversed such that the sleeves were in the car, then the car inlet would be subject to the damage instead of the charger connector - and then use of the adapter would be at the risk of damaging the car, not someone else's charger. That's the biggest issue I see.
Beyond the product public/employer safety issues where the approved equipment is misused and/or unapproved adapters fails.
The unauthorized pin contact can contaminate the socket of the Tesla output connector which in turn can damage a previously undamaged charge port pin. Same thing happens with a damaged receptacle destroying perfectly good cord plugs.
I agree there is a real threat to the reliability of the Tesla charging network; including HPWC, Supercharger and Model S/X charge-ports.
