Um. Going back to the 3-phase stuff. Commercial power is usually 3-phase; that's how it comes from the utility, anyway.
Each phase to ground/neutral is 120 VAC. From phase to phase (that is, hot to hot) one gets 208 VAC. If the phases are labeled A, B, and C, and the neutral is N, then (A->N), (B->N), and (C->N) are all 120 VAC. (A<->B), (A<->C), and (B<->C) are all 208 VAC. Finally, for a quiz about to appear, if Phase A is at 0 degrees, Phase B is at 120 degrees, and Phase C is at 240 degrees.
208 VAC counts as Level 2 and is handled by the car as such.
Now, say you're in a commercial establishment. All they have is 3-phase. You can still get 48A, but the voltage for Level 2 will be 208V. With 60A breakers, the power level will be 208 * 48 = 9.98 kW. With 50A breakers, you'll get 208 * 40 = 8.32 kW.
All right. If commercial power is what you've got (and it's a condo, it might be all they've got, it's the power company that decides upon the transformer, I'm pretty sure), then 208 is in your future.
