You can't reassign ip addresses on the neurios, without re-bonding them to the Gateway.
My recommended order of events is;
BG
- Power up the Neurio #1, and configure it for the SSID and static address reserved below (notes elsewhere here)
- If the static IP address and SSID is already set, you can skip this.
- Ditto for Neurio #2
- Reserve static IP addresses for Neurio #1, #2, and the Gateway in your router, save it, and power cycle your router
- Then check that the addresses are in your router after rebooting.
- If possible, get the MAC addresses for your Neurios at this point
- Make sure that all three (Neurio, and gateway) are on the same network (SSID)
- WiFi repeaters are highly discouraged as they often shift the IP addresses, and the addresses may not be stable over time, e.g. after a power glitch. My advice is never, but a few folks here have gotten them to work.
- Power up the gateway and via the TEG-XXXX network,
- Set the SSID and password for the Gateway in the Gateway
- (you will need installer access rights attached to the login credentials you are using)
- Set the address for Neurio #1 (I recommend that you have the MAC address of the Neurio available, so you know which device is which) and save it.
- Set the address for Neurio #2 and save it.
- Power cycle the Gateway (via cutting the power completely and then pressing and holding the reset button)
- Check on your router that the Gateway is now on the right SSID, at the correct address.
- Check that the Neurios are where you expect them to be.
- You should be good to go.
BG
