I'll try that today, after I finish getting my app to talk to the local wizard-API. Looks like there's no way to set the backup_reserve_percent, from my usage of it. No matter what I set the value to, it's now always 5% when changing/setting to self_consumption mode.If you want to get Powerwall to ignore your solar production and just track your consumption, you need to set set the solar CTs to Load or Site with the correct sign choice.
When your have solar production, the main Site CTs detect your net consumption (consumption minus solar production), and so to calculate your actual consumption, the Powerwall adds your production from the Solar CTs to the main Site CTs to get your total consumption.
So setting the solar CTs to Load or Site with the correct sign should reproduce this behavior as far as calculating total consumption, while not telling Powerwall you have solar.
If you just disable the solar CTs, then the Powerwall will only see your net consumption.
Cheers, Wayne
P.S. I assume on step 6/12 in the wizard you deleted your solar generator?
Addendum: the wizard doesn't allow coexisting Site and Load CTs. They're exclusive modes to all the CTs.
eg. If any CT is set to Site, the only options available for any CT is Site/Solar/None. If any CT is set to Load (after resetting them all to None), then only options for any CT is now Solar/Load/None.
Yes, I tried deleting the solar-generator on that page of the wizard. The Neurio always says "4 CTs" no matter if they're physically connected. Neither affects locally restoring grid-charging.
