[Confirmed & Update] ID:100 , Park Lock Problem
xiaoteshushu
40
65
China
Before, I said I got Park Lock Problem in this Thread
Today , I finally get my roadster move.
The problem is the Park Lock on the transmission box.
After I disconnected the Lock module from the transmission , and manually switch it to "Unlock" with the gear, I can switch to D/R ,and drive the roadster.
Charging is also OK.
Now , I still get error ID 3005 , and can't switch it to P.
I tested the module , its motor works, so I think the problem is the board inside it.
I'll try to fix the board even though it said "No serviceable". Because it's too hard for me to get the part in China. If you know anywhere I can get this part, please let me know.
PV-EV
416
257
Alaska
Nice job digging deep. I’m pretty sure 3005 is a communication fault which would make sense, but I don’t have any definite information on that one. The acuator has hall Sensors to know the position of the pawl. I’m guessing you already have checked the wiring harness to the TCM and the connector. Notes I have warn the tech to be careful with the fragile connector. Specifically:
“Check parking pawl actuator connector THC3 for loose, corroded or damaged terminals. Note: use caution when seperating as connector is very fragile. Check for open/short circuit to ground/harness damage between pawl actuator connector THC3 and TCM connector THC2.”
xiaoteshushu
40
65
China
It is really hard to fix it. That's broken board
jason.tv
404
371
Florida
that thing is really dirty; hope you clean everything up back there or take a blow gun to it. Also take off the rubber shroud on the motor as debree and buildup gets sucked into there which requires a blow gun as well. Just curious to see how they look.
Hope you fix your issues.
19851078182_1839dded07_c-jpg.88063
