Confused about my max range, given my current charge state
Discussion in 'Model S: Battery & Charging' started by gnychis, Dec 17, 2014.
  1. gnychis
    gnychis Member
    Boston, MA
    I have an 85kWh battery and my car is currently charged to 92%. At that charge, I have 240 miles of rated range. As I understand it, this battery should have 265 miles of rated range at 100%. Would charging that last 8% really take my rated range to 265? The ratio seems off.
  2. stevezzzz
    stevezzzz R;SigS;P85D;SigX;S90D;XP100D;3LR
    Colorado
    Very few Model S85 show as many as 265 Rated miles with a full Range charge, and then usually only when they're new. Many cars in use for a year or so show 250-255 rated miles at the end of a Range charge. It's just a fact of life when dealing with a battery pack that loses capacity slowly with both age and use.
  3. rdrcrmatt
    rdrcrmatt Member
    Milwaukee
    When my P85 was new I saw 272 once on a range charge (firmware 4.x), a year and a few months later, and 49,000 miles, I see 251-256 on a range charge.
    In the end, miles of range on the display don't matter because driving conditions are never the same. Some days I see 255 on my range charge but end up burning more wh/mi because of less traffic to be in line with (and therefor get a slight draft from), or there is a headwind, or whatever.
    I'd only gripe if I don't get at least 72kwhr from my pack from 100% to charge now on the display. And, well I'm not going to push it that far every time to make sure I'm getting my capacity.
    This is one reason I wish we had the option to display SoC on the center display instead of miles. I use the estimated miles display from the average on the energy usage graphs to really see my range.
  4. franknesss
    franknesss Member
    San Francisco, California, United States
    Totally agree on the SOC display instead of miles. At least give the user the option to select how they want to calculate their capacity.
  5. wycolo
    wycolo Active Member
    WA & WY
    And miss out on all the fun discovering that 0 miles means ZERO?
    > I use the estimated miles display from the average on the energy usage graphs to really see my range. [rdrcrmatt]
    Isn't that the same if you chose rated miles for the main display?
  6. linkster
    linkster Active Member
    USAX2
    IMO, if you haven't balanced your pack in a while the range algo's may be slightly off.
  7. CliffG
    CliffG Member
    New Jersey
    It may be related to how much mileage you have on the car:
    A year in, I've only got ~12k miles.
    This+
    Also, this+
  8. rdrcrmatt
    rdrcrmatt Member
    Milwaukee
    No, the range displayed in the center of the dash is based on "ideal" vs "rated" range. ideal is 275wh/mi, rated is 300wh/mi, and what I use, the average on the energy usage graph shows me an estimated range based on the actual wh/mi consumed over the past 5, 15 or 30 miles.
  9. stevezzzz
    Colorado
    Congratulations! You've won the pack degredation lottery... :biggrin:
  10. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    Actually, if you expect to achieve the rated or ideal range by the time you hit zero, then you need to use about 255 Wh/mi for ideal and 285 Wh/mi for rated range. The numbers you suggest will require you to drive the car until it physically stops moving to achieve the indicated range. That is not practical for most situations.
  11. qwk
    qwk Model S P2681
    What does it show when you switch to ideal miles at max range?
  12. franknesss
    franknesss Member
    It doesn't mean that people are going to drive to 0 every time. For me, it's just more useful to have a combination of battery % and projected range. It's mainly personal, but just having a battery percentage doesn't mean i'll drive to 0.
    Rated miles is similar, but instead of using 100% i just have to do a little math to figure out the percentage based off of rated range remaining.
  13. tomanik
    tomanik Member
    Canada
    92% of 265 miles is 243 miles. If you do a full range charge and let it balance out I expect you will be very close to 265.
  14. wycolo
    WA & WY
    Most accurate of all would be having a voltmeter hooked to the pack.
  15. CliffG
    CliffG Member
    New Jersey
    dunno, and don't know when I'll charge to max next. Hopefully, I'll remember and take pix.
  16. qwk
    qwk Model S P2681
    Please do. I'm curious what ideal is at 265 rated.
  17. Dwdnjck
    Dwdnjck Member
    I just don't these measurements are very exact and I think it is a mistake to expect them to be. When you have a quarter of a tank in car that holds 20 gallons, do you expect that to be 5.00 gallons? There are 7000 batteries in the car. I really don't think one should expect a truly accurate measurement of charge or range. It's best to give yourself a good cushion, control your speed, and not try to be too fine.
  18. hiroshiy
    hiroshiy Supporting Member
    Tokyo, Japan
    I'm not sure this is the right thread or not, and don't intend to hijack the thread, but my biggest "typical" number was 394 km or 246 miles. Did three range charges since I received the car in September. BTW Japanese cars have Rated, which is based on 275Wh/mile, and Typical, based on 300Wh/mile.
    Isn't this a bad battery? Should I be concerned? I have about 5000 miles on my odometer.
  19. ToddRLockwood
    ToddRLockwood Active Member
    Burlington, Vermont
    I believe this is related to the ambient temperature. When Tesla released it's last major software update, it included a new algorithm that takes the ambient temperature into account when computing the Rated Range. Chances are, your battery has as much capacity as ever, but the car knows that it won't take you as far in the cooler weather (due to heating of the interior & the battery itself). Here in Vermont, I get ~250-255 miles on a 100% charge this time of year.
  20. TTT
    TTT Member
    San Diego
    How do you balance your pack?
