You can reply to the email and ask them how much your check was. Mine was surprisingly higher than I thought it would be.Hi Powerwallers,
I got my Summer 2020 email from Tesla earlier and I was surprised that it said only 35 events were called. I guess we'll see when I get the check, does that seem low to anyone else in Middlesex/Essex MA?
It's was the exact same amount of events.I haven't looked back too deeply yet but I feel like way more than 35 events occurred. How many did you get in RI?
Any one come up with a way to watch the number of discharge events through the API? The Tesla mobile app doesn't seem to track this, but I was able to look at the Energy Usage graph by month and I can count the lines (days) below the 0 line. I had 22 in July and 13 in Aug for 35 total summer "To Grid Services" events. I think it lines up, but always worth double checking! If you wanted to go further I suppose you could start looking at the total energy/event length and true that up to your actual payment as well.
Your meter back spins during the events they pull so you do get the credit of everything your sending back to the gridI wonder how much profit Tesla is consuming from this. If my math is right, they pocketed $270 from me for the 30 events this summer. How much overhead does it really take Tesla to manage this? I don't see anything in the FAQs, just the fine print of the agreement on the 20% cut Tesla gets. Also, they required a W-9, so should I expect this to be taxable income, further dragging the net value of this program down. As we're in a net-metering state too, I am worried that I have consumed some of that net metering value and now I am going to be getting a bill from the power company in Feb, Mar, Apr.... I am thinking, this program may not be worth it, once everything is calculated.
How does CS work for a state like NH where it's not quite 1:1 net metering?Your meter back spins during the events they pull so you do get the credit of everything your sending back to the grid
I have no idea. I know in RI it's 1-1 and I received over $1400 per powerwall after Tesla's cutHow does CS work for a state like NH where it's not quite 1:1 net metering?
Yeah, but the issue is, and why I don't use the PowerWall everyday, is everything that is produced by the solar, right now, I get credit for and turns it backward.Your meter back spins during the events they pull so you do get the credit of everything your sending back to the grid
I use my powerwalls for backup usage. I am not pulling out of the PWs daily except when National Grid calls for an event.Yeah, but the issue is, and why I don't use the PowerWall everyday, is everything that is produced by the solar, right now, I get credit for and turns it backward.
1. Solar makes 10kwh = 5 kwh to house + 5 kwh to grid
2. Solar makes 10kwh = 5 kwh to house + 2.5 kwh to grid + 2.5 kwh to recharge PowerWall
The numbers are way off, but the example is just to show it is not beneficial, as I either push the power back into the battery and don't get credit for that power, or push the power back to the grid and get 1:1 credit. I only lose by using the powerwall for recharge cycle (wear and tear) and incremental power loss changing DC to AC.
