Hi there, I am new to the forum, just picked my Model S on Friday, and am LOVING the car !! ....its my first electric car, I came from a BMW 745i..so it's quite the change for me... i am CDN Sig # 151 VIN 2113 i have a galaxy nexus phone, which works fine with the car but under the call logs, the dates are all messed up, showing the call logs as 1969 dec 31 ??? ...see attachments below...and the contacts don't sync at all..just get a continually circle loading animation... i am on v4.41.. Updated 1 day ago..and it was fine before that...so I am not sure if this a 4.1 issue ? Thoughts ? Anyone else have the same phone with 4.1 ?
So anything I can / should do ?.. 4.0 was fine..I might try resetting my screen...but just wanted to see if any other nexus owners had this issue also.
Do you have a cdma Galaxy nexus or a gsm Galaxy Nexus? I ask that because you say your are on android 4.1 right?
Interesting... I am on Android 4.1.2 - AOKP Maguro jb milestone 1 build - lean kernal 4.5.0 I guess, i should try to reset the screen and see if that works.. - - - Updated - - - I have GSM
Well I reset the screen ( press&hold both steering wheel scroll buttons )... but still same problem.. i'll see what service has to say..
Can you update to Android 4.2 on the Galaxy Nexus yet? I have a Nexus 4 and it works perfectly with 4.0 in my car. I've been away at my parents house in NH for the holidays, but I'll see if I have 4.1 available when I get back and if it works OK with my phone afterwards.
thanks Tim, I'll check if AOKP has a build out for it yet and try that.. But today my contacts at least synched properly, but the date/time stamp still show 12/31/69 11:59 for everything.. i called into factory service, they mentioned some newer devices dont even pair properly, like the Samsung Note II , so he put service note that will go to the field engineers
