Does anyone happen to know what part number or model of connector plugs into the electric parking brake motor on the red performance rear calipers? I'd like to build a cheap 9v adapter harness to make it easier to retract the EPB screw when swapping pads.
Resurrecting an old thread... but I think I found the female connector on Mouser. I'd buy the TEVO one but I'm not really interested in spending $60 (for something that can be built for under $10)
DISCLAIMER: I have not confirmed the 9441291 is the correct connector - this is purely based on a visual comparison on the TEVO harness and options I found on the web. I have a bit more research to do and then intend to buy a set of parts and try it out. Curious if anyone else has had success finding this and building their own.
@MasterC17 @destructure00 @MountainPass
Here is a photo of the harness TEVO sells:
TEVO Harness
Based on an image search I found:
Kostal 2-pin plug
Which led me to DeyTrade (EU):
Kostal 9441291
And finally, searching Mouser:
Kostal 9441291 ($4.40 each, need one)
I think the associated terminal (pin) is this:
Kostal SLK 2,8 22140492060050 ($0.90 each, need two) - its listed under the female connector "customers also bought" section, and seems to match the SLK 2,8 designation.
Last bit is the 9v harness. I found a plethora of options on
Amazon ranging from $0.50 to $3.00 per harness (need one). Add some solder, insert the pins in the right orientation to achieve retraction, connect a battery, and I think you're off and running.
