Connector vs. supercharger
Discussion in 'North America' started by CdaleP85d, Feb 5, 2015.
  1. CdaleP85d
    CdaleP85d Member
    Cdale, CO
    Ordered our P85D for March delivery.
    There is a Supercharger 15 miles from home and a couple Tesla Connectors up to 80kw.
    Will we be able to charge our p85D at the connector locations but only up to 80kw or are we incompatible for that type of charger?
  2. dbullard
    dbullard Member
    Superchargers bypass your car's chargers - and they typically charge at 120kw.
    You're good :smile:
  3. markb1
    markb1 Active Member
    San Diego, CA
    Perhaps you mean 80 amps (the maximum current of an HPWC). That's 19.2 kW at 240 volts. You can certainly charge at one of those. Whether you will get 80 amps or 40 amps will depend on whether you have dual chargers.
  4. Killface
    Killface Member
    Tempe, AZ
    And it'll also depend on what it's wired for. A surprising number of HPWCs are only wired for 40 amps
  5. Cottonwood
    Colorado
    There are also a few HPWC's out there that are wired for 80 Amps, but the DIP switches were never changed from the factory default of 40 Amps. Breakers, wires, etc, all ready to go but waiting for DIP switch settings. Apparently, some electricians don't do DIP switches...
  6. scaesare
    scaesare Well-Known Member
    NoVA
    Hmm... maybe it's time to add a Torx driver to my charging kit...
  7. markb1
    San Diego, CA
    This is true. Though hopefully if some site is identified as "80A", it really is wired for 80A. But, of course, there are no guarantees.
  8. TEG
    TEG TMC Moderator
    And just to make sure it is very clear - the Superchargers will fill up your car much much faster than the 240V AC charging spots.
  9. gjunky
    gjunky Trifecta: Solar and both cars are EVs
    Scottsdale, AZ
    I am kind of curious. Why are you so interested in the external chargers? It is of course fine but can you not charge at home? Do you plan to install a HPWC at your house?
  10. JackA
    JackA Member
    Orondo, WA
    While charging at home is the most common, after about one week of ownership many of us starting planning longer trips. L2 and more specifically haL2 or L3 charging opportunities make these trips much quicker. Our first long trip was from Wenatchee, WA to Banff, Alberta just under 500 miles. We were able to use some haL2 (70A 240V) chargers that added about 50 miles of range per hour of charge. So in very general terms we spent an hour charging for each hour driving. Of course many of the charging hours were while we slept at a hotel with a charger. If we had Tesla Superchargers or even CHAdeMO L3 we would have a much higher ration of driving to charging. ChadeMo 3:1 Tesla SC 5:1 (all of this is not actual and I am basing it on my own 50 MPH actual travel time). So, the more charging opportunities available on a route the more likely EVs will travel there.
  11. N4HHE
    N4HHE Member
    Madison, AL
    You really shouldn't change someone else's HPWC configuration. It might really be on a 50A circuit rather than 100A. It might be intentional so other things on the same service can continue to function.
  12. ken830
    ken830 Model S 85, Model 3 Performance
    San Carlos, CA
    And you'd also be hard-pressed to find a HPWC installation hooked-up to 240V in a non-residential location. It'll probably be 208V (nominal), so you'd only get 8.3kW or 16.6kW.
