I'm in the process of having Tesla quote me a Powerwall 2 setup and I had some questions for other PW2 users.
My arrangement suggests I need 3 PW2's mounted on a pedestal/frame near my main service entrance which is located about 50 feet from my home. My primary purpose is to provide emergency backup plus prepare for the new TOU tariff by PG&E which shifts the peak toward the evening and away from the optimum solar production time. I currently am on the PG&E E6 tariff and have about 15KW+ of solar which is slightly above my usage. I have 3 separate solar systems, 2 each SMA 7000US's with each producing about 5.5KW and another based on 17 Enphase M215 micro-inverters which produces about 4KW.
Each PW2 will serve one solar system. The PW2 and the solar system ( of 3) will have its own sub-panel. These will be combined to serve my 2 home sub-panels of 100A and 200A. My well water pump, my irrigation water pump, and my pool 100A panel will not be backed up and remain on my existing 200A service panel. The Tesla gateway will isolate ( disconnect) between that main 200A not backed up panel and the 3 PW2/solar panels and the 100A and 200A home sub-panels.
I will need a ground mounted frame to hold the PW2's and various panels and the disconnect switches for my solar systems. Tesla sent me specs for this frame and its a bit ridiculous in its details. Does anyone know if the frame with concrete, posts etc.. specs are rigid as it looks like gross overkill and could be expensive? If Tesla specifies it in a rigid way, I know my county building department will demand it be perfect. I fear the simple frame could blow the budget plus it must be done in a tight location and it might not be practical to meet the details of their specs. Does anyone know how rigid this is? Since the PW2's would be stacked and their weight on an existing concrete pad, the frame itself would not carry much weight. Any thoughts here?
Are there any online tools that provide any kind of modeling for PW2's, solar and usage power and flows?
If I have 3 PW2's then there is 40.5 KWh of backup power when the grid is down. Each is capable of 5KW or 15KW of total power during backup. If a water pump turns on during backup, it draws significant startup power/current. Do the 3 PW2's load share all the power drain equally while in backup. This would suggest that all loads combined while on backup must not exceed 15KW but it doesn't really matter where the load exists on any of the sub-panels. Is this true?
What happens if by chance the PW2's are overloaded during backup - load exceeds 15KW. Do they shut down nicely? If the load is removed, will they come back on? Can they be restarted manually? How is this done?
If in backup, the 40.5KWh is reached, do they shut down cleanly? Then when the sun comes up and solar begins charging the PW2's, how do they restart? How is all this managed? Automatically? Manually? Could someone explain how all the various cases work and how much is automatic and how much is manual?
Will backup work if the internet is out? Can things like restart be done without the internet? besides the nice data collection and app features, do things basically work for backup when the internet is down? I suspect most peoples internet is dependent on local power and therefore is lost during a major outage or emergency like an earthquake or fire.
thanks
thanks
