Considering solar panels, looking for sizing/financing advice
BrettS
2,108
2,511
Orlando, FL
Yeah it's definitely backwards. And for some reason the long-term data part of the app seems to know it, but the live data part does not. It somehow thinks I've supplied 40 kWh to the grid via means other than solar.
Perhaps it thinks that you have a bunch of trained hamsters running on wheels generating power day and night to feed into the grid;)
The solar production data comes from your inverter and the data about the power going to or coming from the grid comes from the power blaster, so it’s possible that your inverter just hasn’t been associated with your account yet. Hopefully once they get that done things will look more normal.
Reactions: willow_hiller
willow_hiller
2,950
12,671
Maryland
It's definitely worth checking out some of the support videos: Troubleshooting Your System | Tesla Support
I was considering power-cycling my inverters and/or the gateway, and then at the very end of the video it says "Production may take 24 hours to appear."
So I'll give it a day and see what happens!
EDIT: I'm also guessing that while the live data monitor doesn't know about the inverter, it's got an automatic flip for negative numbers. It would be really funny if they thought they had installed my CTs correct, and came back to "correct' them and only end up doing it wrong.
Also @wjgjr , the way this wonky data is coming in might help answer some of your questions about production measurement. I'm not seeing anything on the live data page, but the aggregate data page is updated once every 15 minutes in sync with those DNS requests I'm seeing on my home network. So I'm guessing it's polling the total production from the inverter itself at that interval. Maybe the odd data artifacts you were experiencing earlier are from a disparity between the CT data and the inverter data.
willow_hiller
2,950
12,671
Maryland
No luck with monitoring this morning. Tried resetting the gateway, resetting the powerblaster, resetting the inverter. At least this is a good opportunity to test the "Service" button within my Tesla app.
Immediately got an email and a text message after submitting a request, promising a response within 3 days. And it shows up when I click "Service" again in the app.
willow_hiller
2,950
12,671
Maryland
Looks like I was granted an extra 1,000 panels or so :eek:
willow_hiller
2,950
12,671
Maryland
And we're golden! They must just have 101 different configuration options on the home server that need to be set right.
After plugging the car in:
Fixed within hours of submitting the in-app service request. Definitely worth trying! I wish it was easier to set the car's charging amps from the app.
willow_hiller
2,950
12,671
Maryland
Although the live data was a bit wonky, it seems like I got a nice curve in the data. Peak of 8.2 kW, and lasts from 7 AM to 7 PM. Seems a little bit steep, but I guess that's due to the time of year? And no sign of clipping, so I can check that unwarranted fear off the list!
wjgjr
974
731
Silver Spring, MD
That seems about what my chart looked like today (other than being barely over half what you generated with my smaller system.) What size is/are your inverter(s)? I ask because at least in my case, the max instantaneous generation today is roughly 80% of its June peak. Realizing that ratio is somewhat array-dependent, if it does hold for you, you might see peaks a bit above 10 kW.
willow_hiller
2,950
12,671
Maryland
Living vicariously through you as I wait for my install date. Already have an approved interconnection agreement with my utility. Just need some panels on the roof and an inspection!
Hang in there! It's all worth it in the end :)
If nothing else, this whole process has taught me a lot of patience.
jboy210
4,640
2,889
Northern California
One 11.4 kW SolarEdge inverter. I was telling my wife this evening, if this is what we're getting in late September, I'm excited to see next Summer!
Definitely. We saw 55+ kWh/day in June and I was shutting down the system at 1PM because we did not have PTO. Now down to mid 20 kWh/day with the system up all day because of more shading and low sun.
morbidz
68
84
nj
always good to see the same size system in the same geographical area to compare results.
willow_hiller
2,950
12,671
Maryland
Just as an aside, does anyone else have odd historical data? When I go to see Lifetime stats, it says my total is 56.4 kWh. But when I download the CSV it shows an "Energy" column (that sums to 56.4 kWh and seems to forget most days) as well as a "Cumulative Energy" column that does appear to be working correctly, but isn't graphed when I do the bar charts.
It's such a minor inconvenience I don't know if I want to bother Tesla about it, but it would be nice to have the graphs in the phone app working okay.
