Thanks willow_hiller. Not sure why the CA sales tax was assessed then.
Thanks for your reply. I do have flat lightweight concrete tile. I was concerned about this first, but a bunch of people seemed to indicate that they did install on concrete tile. Also, I talked to them on the experience line and they said concrete tile was supported as long as it was of supported weight. Perhaps this is some sort of regional policy? There are tons of houses with flat concrete tile here so I imagine Tesla not supporting this installation would be quite apparent?
Ok, good to know. Whatever you do... make sure your install gives you a quality mount on your tile roof.
I spoke with two roofers in my region and they said they've seen so many pissed off homeowners with solar on tile roofs that they now advise anyone with a tile roof to say "no to solar". I'm not a big fan of a blanket statement "no", so I dug in deeper to learn why there were problems. Here's what I learned:
1) There are four methods of mounts that work with tile roofs; tile hooks, stand-offs, tile replacement mounts, and the "three course" method.
2) Tile hooks seem great, but can be problematic since cheap/poorly fitting hooks could impact the tile below. If your installer uses hooks you have to make sure that if wind pushes down on your array it doesn't cause the tiles on the lower course of roofing to bear any unexpected loads. This could involve grinding tile or paying extra for the thickest/strongest hooks.
Example... imagine what happens if weight were on the hook pressing down on the tile below it...
SnapNrack Introduces the Flat Tile Roof Hook to Reduce Solar Installation Times - SnapNrack
3) Stand-offs are the "old school" method and involve grinding a big hole through a tile flashing under the tile. Just say NO to this method. There is no good version of this method.
Example... just imagine your roof full of those ground away tiles:
Imgur
4) Tile replacement mounts could be a good solution, but installers often find the replacement tile doesn't actually fit well with your roof tiles. But it should be a good option if you're a good candidate try to get this. I was not though.
Example... flat, S and W tiles:
The Replacements: These solar mounts for tile rooftops cut labor costs, avoid OSHA issues | Solar Builder
5) The three course method still has a bit of grinding, but involves a bunch of extra flashing and seals. If this is properly done, this mount WILL NOT LEAK. It's the "bulletproof overkill method." The solar mount will not be to blame for future leaks; those will be the fault of your aging roof or a skylight issue or something. This is costly, but worth it if your installer is game.
Example instructions I ran by my installer and made sure they said "yes" to this:
Imgur
6) Schedule to have a roofer inspect your solar right after it goes up. If they find anything amiss you're in a good spot to get it addressed before it ages and the finger pointing begins.
7) Do NOT assume some solar install/leak warranty is going to save you from leaks down the road. Pay the extra to get things mounted very well.
Tesla wouldn't even go with the hook method on my roof, so I never found out whether they'd even bother with the tile replacement or three course method.
