Considering upgrade to adjustable suspension - need your input
Discussion in 'Roadster: Performance' started by sethr, Jul 24, 2013.
  1. wiztecy
    wiztecy Active Member
    Please take pics, can't wait to hear about the outcome!
  2. frequencydip
    frequencydip Sig 100 - #52
    Los Angeles
    My car is out of warranty, so no issues there. We focused on two line items, unsprung weight and new shocks/springs. It will have a few things above and beyond Tesla's performance suspension. Double adjustable - rebound and compression, ride hight adjustable with ability to corner balance, increased camber, more adjustability for caster and toe. For unsprung weight we are thinking we will lose about 12Lb. This will increase tire wear but I have not been as concerned as others about that, I'm hoping tire wear is limited to replacing fronts at same time as rears but rear tires may wear slightly faster too. Don't have final pricing yet but it will be more than Tesla's package. Here is a photo of all the parts we replaced.
    On a side note Tesla would not sell the adjustable swaybars separately from their packaged upgrade and for that they suck.
  3. wiztecy
    The swaybars I heard are not Tesla specific, so you should be able to buy them from the manufacturer or cross reference it to a Lotus. You'll just need someone on the forum to read off the front and rear swaybar part number and list them here for you....
  4. hcsharp
    hcsharp Active Member
    Vermont
    Actually they are Tesla specific.
  5. wiztecy
    Menlo Park told me differently, that they're just Eibach's and not specific. They said I could call Eibach if I wanted the set but I couldn't do that for the bilstein shock and springs since that was specific to Tesla. Now I'm lost.
    If anyone can take the time and read the part number off their Eibach Sway Bars from a Roadster Sport that be great. I think I asked this 3x in the past and nobody responded :(
    With that we can do some calling and find out what's true or false.
  6. djp
    djp Model 3 Performance
    Toronto, Canada
    If you've done the cold weather upgrade for the PEM fan and shroud, you already have the adjustable rear sway bar. Only one version was built to fit around the new shroud.
  7. wiztecy
    If that's the case then like Henry indicated it IS Tesla specific and I don't see Eibach wanting to make a few batches for some random customers.... will ask Menlo to clarify the next time I'm in...
  8. djp
    Toronto, Canada
    I'll check for part numbers later this week. I have the old non-adjustable front sway bar in my garage and the adjustable ones are on the car. I'm now wondering if there are two versions of the rear adjustable sway bar, one standard and one custom for the fan/shroud upgrade.
  9. wiztecy
    Thanks, that'd be great to fully understand what's what and why :)
  10. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Definitely yes. I have the adjustable suspension and they did replace it when I got the fan/shroud update.
  11. hcsharp
    Vermont
    Yes there are. I wonder what they did with hundreds of old rear sway bars after they were replaced with new ones? Same with all the old fans?
  12. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Sway bars are incredibly easy to copy. If tesla will not sell you theirs, have them copied!
  13. frequencydip
    Los Angeles
    We did discuss building our own swaybars, its something I may do in the future but would need to do a group buy or something to make it worth it. The first sway bar is expensive, each copy there after is cheap in comparison.
  14. bart513
    bart513 Active Member
    East Hampton
    I had my fans and shroud replaced for my 1.5 non sport. I assume that they didn't change the sway bar? I wish there was a less expensive way to upgrade the suspension. I purchased the ESA so I'm under warranty for non battery items....
  15. wiztecy
    If it was the front fan with the shroud then the sway bar didn't get changed. If it was the rear PEM blower then yes, since the new blower design would have hit the old swaybar.
  16. djp
    Toronto, Canada
    I poked my head under the car today to check for part numbers. Unfortunately they're printed on the centre of the sway bar so I'd have to remove the diffusers and shrouds to see them, which is a bigger project than I planned to take on. I was able to get the part number of the non-adjustable front sway bar, it might be possible to find the corresponding adjustable part number from Eibach.
  17. bart513
    East Hampton
    Did they replace the rear fans for some reason in the 1.5's? If valid then I can ask them to replace them at the next service visit.
  18. djp
    Toronto, Canada
    It was only done for cars in harsh winter climates, the new fan and shroud do a better job of keeping the snow out. You can ask at the service centre but they'll probably charge you for the replacement.
  19. Doug_G
    Ottawa, Canada
    Also it's only a 2.0/2.5 mod, I believe. The 1.5's have a very different PEM.
  20. wiztecy
