Constant low whine present when car is parked
Discussion in 'Model S' started by ecarfan, Oct 4, 2016.
Tags:
  1. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    A friend of mine has had his CPO S60 for about a year now. For the past 3 days he has noticed his car makes a constant low volume, high pitched whining sound. He hears it when the car is parked, plugged in or not plugged in. I just listened to it. It's coming from the front of the car, clearly audible standing next to the car inside the garage where it is parked, loudest when you get your head underneath the front end. I can't lateralize it. Audible while driving but only at low speeds and playing music drowns it out. If the car was located in a noisy place I probably wouldn't notice it if I was standing next to it.
    Anyone had this?
    Note: car got V8.0 a week ago, the sound started over the weekend, so several days after the software update. I think it is unlikely the sound is related to V8.0.
  2. ecarfan
    San Mateo, CA
    My suspicion is that something is running that normally is shut off when the car is at feast.
    He has re-booted the IC and center display without effect.
  3. Hugh Mannity
    Hugh Mannity Mediocre Member
    Port Haney, BC
    Battery re-conditioning is my best guess. My car does this often, very noticeable in quiet garage.
  4. ecarfan
    San Mateo, CA
    The Model S I posted about has been making that noise continuously, as near as the owner can tell, (even in the middle of the night) for over 3 days. I nearly a year of ownership he had never heard the noise until the last 3 days.
    Does your car run the battery temperature management system continuously? I suspect not.
  5. evp
    evp Nerd
    Arvada, CO
    If he just "upgraded" to 8.0, we must consider the possibility that it has something to do with the new "keep the interior temperature lower than 105 degrees" feature, possibly combined with a failed interior temperature sensor.
  6. Btr_ftw
    Btr_ftw Court Jester
    Mass
    Can he pull the frunk to see if it's one of the coolant pumps? How is his vampire drain?
  7. rypalmer
    rypalmer Active Member
    Canada
  8. habanero69
    habanero69 I Dont Need Cialis. I Drive an EV.
    FLorida
    Probably a coolant pump. I have that sound from time to time. Vampire may also be a decent way to tell if it's "pump" or other big ticket item related too.
  9. ecarfan
    San Mateo, CA
    I don't think that is it. The HVAC works normally so the interior temp sensor is likely working correctly.
    Ahah! That thread sounds like it is about the same noise, and it is the battery cooling system running. Of course the cooling system should not run continuously for over 3 days unless the environment is constantly extremely hot. That is not the case with my friend. We live in San Mateo CA just south of San Francisco near the coast. For the past several days the daily highs have been 70 or less. Nightly lows in the 50's. He parks his car in his garage at night. He drives about 60 miles roundtrip to work on the SF Peninsula. So temps have been quite moderate and there is no reason for the battery cooling system to run continuously. Also, he's owned his car for a year and it has never made this sound continuously before. In fact the sound is new to him.
    I think the battery cooling system in his car "glitched" and remained on continuously for some reason.
    And he just emailed me to say that when he went into his garage this morning at 5:30 to check the car the sound was not present. First time in well over 3 days he has not heard it when standing next to his car, day or night. It's stopped.
  10. Btr_ftw
    Mass
    Also have him plug the car in to charge to see if he hears it again. A friend of mine when he charges at 110v the pumps turn on at high speed for a brief point in time, they then spin at regular speed as time goes on
