Continental ExtremeContact DWS 06
Discussion in 'Model X: Driving Dynamics' started by Krazaak, Oct 12, 2017.
  1. dailo
    dailo Member
    Bay Area
    After seeing the light on my dash initially, I haven't had any issues with my 255 fronts so seems to have fixed itself. Tires have performed well so far. Thanks everyone for all the info!
  2. flar
    flar Member
    How bad is the lower rating on the 265s? It's only about 55 lbs per front corner and the tires are rated for far more than (1/4 of) the GVWR of the car anyway. Or is the SL vs XL rating more significant than the load rating number?
    Towing would stress the rear tires (with a much higher 110 rating) more than the fronts.
  3. Solarman004
    Solarman004 Member
    Colorado
    I took advantage of triple rebates (Black Friday, Continental, military) today at Discount Tire to purchase a set of ExtremeContact DWS 06.
    As others have stated, the 265/45R20 (front tires) only come with a 104Y rating which should be fine for my MX 75D. The 104 rating is 1984 lbs, and the front GAWR for my car is 3241 lbs. So half of the axle rating is 1620 lbs, which is well below the 1984 lb tire rating. However, Discount Tire would not sell me this tire in the 265/45R20 size because their computer kept indicating that it did not meet load requirements for a 2016 MX 75D.
    So, I ended up buying the ExtremeContacts in the 255/45R20 size for the front. I won't be able to report back with any impressions for a while...I put on my 19" winter tire/wheel set today, and just dropped off my 20" wheels, not the whole car, to get the ExtremeContacts mounted.
    I do need to have Tesla check my alignment. I only drive in "Standard" suspension height, but my right rear tire was warn 2/32" more than the other three tires, and worn more on the inboard side than outboard.
  4. Dazureus
    Dazureus Member
    Michigan
    1 year update. I just swapped my Continental DWS 06 for my winter tires. They've performed well but I'm disappointed by how much wear the rear tires have after just one year.
    Drivers side rear
    Passenger side rear
    The fronts don't have this much wear and both the rears are at or very near the wear bars after just one year and maybe 15k miles. I do have a P90D, but don't tear out of every stop light. When I got these installed, I had a wheel alignment done to fix the uneven wear pattern on the stock tires. The wear on these looks even, but seems excessive considering they were the highest tread wear available on tire rack. They'll need to be replaced, and I'll probably just go with the same until the fronts need replacing too, but it's disappointing that I need to replace my tires every year. I would expect this from high performance summer tires, but didn't expect it from all season tires.
    • Informative x 3
  5. Krazaak
    Krazaak Member
    Charlotte, NC
    #45 Krazaak, Dec 3, 2018
    Keep in mind, this is an ultra high performance all-season tire. It's basically a compromise of a little bit of summer performance for a tire that can actually function in the cold or in a light snow. In my experience on my BMWs, they were slightly better tread life than summer only tires, but not much. I was hoping to get 16-17k out of mine, but looks like 15k and I'm on the bars.
    Guess I'm off to Discount Tire to see how much credit I'll get towards the next set.
  6. Need
    Need Active Member
    SoCal
    I guess I need to check ours... it is almost 1 year and just saw that it got 15.6K miles. Although I don't think they are that bad because we just took it to the tire shop last month to patch a screw. I would think they would tell us if the tires are worn because they would want to sell us new tires.. as the patch was free.
  7. madodel
    madodel X at the end of a rainbow
    Poconos, NE Pennsylvania, United States
    I've got 21,000+ on my Continental Extreme Contacts and they are now at the wearbar so need to replace. I've been very pleased with them but was wondering if anyone has found tires other than the Extreme Contacts they recommend for an all season replacement on the Model X? They lasted considerably longer than the original Conti-Silents, are quieter than the Silents, gives a really nice ride but there is about a 10% hit to range with the Extreme Contacts.
    Anyone found an All-Season nice-riding tire that also gives good mileage or is that mutually exclusive?
  8. Krazaak
    Krazaak Member
    Charlotte, NC
    14,007 miles, rears at 2/32, fronts at 6/32. Thought I was closer to 15k, but guess not.
    Replacing only the rears, $195 installed after the $344 pro-rated credit for tread wear.
    I really don't think there's anything that's going to survive a P100D without compromising on handling. Still a better choice hands down than OEM, since they had no tread wear warranty.
  9. Yinn
    Yinn Active Member
    Behind you
    I ended up going with Nokian WRG3 from SimpleTire. It's an "All Weather" tire that's geared more towards snow. I chose it due to the high rate of wear typical snow tires get; and this had a 50,000 mile treadwear warranty.
    So far, I love the cold weather performance. It's significantly better than the Conti Silents and DWS06, the ride is comfortable as well and not too loud despite not having the foam cancellation. The mileage is also good on these. I've been able to get as low as 250wh/mi on these and average about 350wh/mi in the cold. For comparison, I was typically around 385wh/mi on the Conti-Silents, and about 420wh/mi on 22's w/Pirelli's in the summer.
    On the negative side, the compromises are obvious on this tire - at least to me. Specifically on higher highway speeds (75mph+) I personally can feel the tire - waddle if you will. Turns feel numb and uninspiring, and I find myself driving significantly slower and less aggressive with these tires. I do caveat all of this with - I am able to feel this. Nobody else in my family who drives this car feels any of this and swears I'm crazy. Everyone else doesn't notice a difference between the OEM contisilents and the DWS06, or the WRG3s.
  10. Kacey Green
    Kacey Green Member
    Charleston, South Carolina, United States
    I'm pushing 7k miles and watching this thread eagerly for data points. Our P100D is currently wearing 20" Sonic Carbons and the OEM tires. We live in South Carolina, but do travel to places where it might snow, shoot last year we got a few inches here in Charleston and it rarely snows here.
  11. Dazureus
    Dazureus Member
    Michigan
    Looking back at my service requests and dates, I was off about how much mileage I got from these Continentals. I'm guessing it's closer to 23k miles, which is still less than I would have thought to get. Tirerack has some tire options with higher treadwear ratings that weren't available when I last purchased tires. I might look into those as options, specifically the Pirelli Scorpion Verde All Season Plus. It comes in 265/45/20 for the fronts and 275/45/20 for the rears and has a treadwear of 740. It's an "ecoimpact" tire, so it's supposed to have less rolling resistance, which is similar to the OEM tires.
  12. Kacey Green
    Kacey Green Member
    This was one a buddy and I had looked at, please let us know what you find out
  13. Krazaak
    Krazaak Member
    Charlotte, NC
    I've considered them, but the Tire Rack test results for snow were really bad on the Pirellis. We don't get much snow here, but I want to be able to handle the little bit we do get.
  14. flar
    flar Member
    I didn't see the Verde A/S Plus on Tirerack, but they show in America's Tire web site. The fronts are only H rated at that size.
    The OEM tires on the America's Tire site seem to be dramatically lower in price today than last week - almost $30/tire.
  15. Dazureus
    Dazureus Member
    Michigan
    Yeah, the fronts would be H rated and the rears would be V. Do you not think that H speed rating is enough?
  16. Terthen
    Terthen Member
    San Diego
    I’ve been using the Pirelli Scorpion Verde All Season Plus in those sizes over th past 2 months. They’ve been solid, happy with the choice. I have noticed only a marginal increase in wh/mi compared to contisilents, maybe 5-10 wh/mi more. I only have a 60d so my max speed is 130mph anyways (H rating). I will get these next time I need to replace the tire, saved $800 at the time compared to having Tesla SC replace them with OEM tires.
  17. flar
    flar Member
    H is rated to 130 MPH so it depends on how fast you want to go, but that isn't the end of the story.
    In order to get a V or a Y rating (149 or 186 MPH), the tire construction has to be beefed up a bit and often that improves handling. Here is an article from Consumer Reports that talks about speed ratings (FWIW):
    H-Rated Tires with Shorter Life Spans - Consumer Reports
  18. flar
    flar Member
    So has anyone tried a tire that has better efficiency than the stock Contisilents? It seems that most of the options being discussed come with a range caveat.
  19. Scott Fairchild
    Melbourne fl
    Stay away from Continentals. Catastrophic blowout at 15k miles. They weren't at all interested in even a penny of reimbursement.
    Had my Perellis now for 10K and they are like new with 50K guarantee. $238 at Discount Tire, far better than the $400 ea for Continental Garbage from Tesla
  20. xrobva
    xrobva Member
    Northern VA
    Hey all, been following this thread and am curious to see if anyone has any updates. I did a little digging and my '17 MX specs 255/45R20 for the fronts, but the latest MX manual available online lists the Continental fronts at 265/45R20. I wonder if there was a policy change somewhere in there? I am guessing either will work regardless of model year. If you go to Tire Rack and do a search, the 2016 MX lists 265 and the 2017 lists 255. I didn't check the 2018. I have 21k miles and my rears are getting pretty bad. Looking at either the Continentals or the Pirellis as replacements. Thanks for the info!
    RH
