Continuous Faint Humming Noise When Parked
Mirlen
268
351
Allison Park, PA
By similar problem you mean the pumps were running after charging about 10 hours and your HV battery losing a mile per hour when parked?
Also, how was your issue reported and diagnosed?
As in a constant whirring sound after I parked for hours and hours and continuing as I drove in the morning and could hear while driving. It was noticeably different than normal behavior. I called in to Tesla and they did some things on their end to try to pull data from the car and they said they identified the issue and to take the car in. They contacted the local service center and got me setup and sent them the info.
It was not in relation to charging.
Droschke
2,402
4,300
Future
Thanks for your reply. Please update this thread once you know more from the Service Center visit.
David in NC
83
72
NC
I occasionally open my garage door to find my charging Tesla still on, with dash lights on and sometimes the same fan noise.
If I get my key fob and lock the car, it shuts down and is fine (fan and dash lights off).
I know this sounds simple but did you try it?
Droschke
2,402
4,300
Future
We are not talking about the "fan" noise. The issue here is the cooling "pump" noise. Two different components with different sounds. The fan noise is louder and pronounced. The cooling pump noise is muffled and that's why I called it "humming".
And, yes, the car is always locked in the garage, and was not being charged. It was losing charge.
Droschke
2,402
4,300
Future
Update:
After the pump running for long period of time and losing miles while plugged in during the last two weeks, which happened in two separate days after charging, I've not noticed any new occurrence. The only negative side effect is my Rated Miles are now being calculated down by about 10 miles (my battery has shrunk ;) ). My conclusion is that Tesla, post 2019.16.x updates, executed two separate maintenance routines to calibrate the HV battery on some cars (maybe the announced fire prevention update?). The routines had to run off of the HV battery and that's why the car never used the shore power and kept pulling power from the HVB resulting in a severe vampire drain while pumps were running for hours long.
HyperionP85
Seattle
Update:
Hi, I joined TMC Just to respond to this thread. My car started doing the same thing as described and around the same time frame as well. I have a 2013 model S P85. I have 2019.16.2. Also had two updates since. The ham is beyond what I’m used to hearing and I am on a pretty good first name basis with my car as I spend a lot of time in the garage. It Only happens in the morning after a charge. When I come home from work it’s quiet
Droschke
2,402
4,300
Future
Did you notice for how long and how many miles it took off your main battery? Was it the first time you think?
Mirlen
268
351
Allison Park, PA
I'm not the OP, but in my case:
HyperionP85
Seattle
Thanks for your update. Mine did not reoccur after two occasions. The first time the pump ran about 10 hours and the second time about 5 hours. Both times were after charging. It's been quite since May 24. But I'm keeps my eyes on it.
I talked to a Tesla technician.. he reported no remote diagnostic issues. Also he wasn’t aware of any faults in the new software in terms of thermal management. I saw the video of the blue Tesla (I think bobasaurus..). Mine sounded exactly like that. Exactly.
Droschke
2,402
4,300
Future
Are you still noticing your coolant pump running periodically?
Droschke
2,402
4,300
Future
Same issue here with a 2013 P85+. First time hearing it today. Any updates on what is causing it? Software 2019.16.2
Tesla never got back to me, so no official cause.
However, this my speculation:
- Caused by 2019.16.x
- Happens more than once
- It's HVB calibration/adjustment on older cars
- Results in lower Rated Miles calculated
pairtrader
209
13
Vancouver
This is happening to my car now. Exact same noise. 2014 S85 VIN 329XX
I'll wait a few days to see if it stops as expected.
I'll update once resolved.
Droschke
2,402
4,300
Future
Also, as I described earlier, expect it to run more than once with the first occurrence longer the the second. Mine ran for about 10 hours the first time and about 5 hours the next day. No more since then. I would be interested to see your Rated Miles drop, if any. I got 7.5% decrease on my RM. That's significant.
xceler8tion
73
34
Did your real world milage decrease as well? I only get about 70% of whatever the rated miles (ie. 229 miles on the indicator nets about 160 miles of real world range). P85 with 21" wheels here.
Droschke
2,402
4,300
Future
I've not noticed the real world mileage change since I do not drive that much. But, with the short drives of less than 50 miles, the actual miles used looks the same as the RM usage, i.e., if I drive 30 miles I lose about 30 miles off of my RM. This has always been the case as my lifetime average Wh/mi is about 287 (The car has 43K on it).
What's your Wh/mi and the car's mileage?
