Yes. Check out their site and blog.
The brakes really have nothing to do with regeneration because you control how much to use them. The Tesla is not like the Prius where most of the regeneration is on the brake pedal. In the Tesla every bit of regeneration is on the accelerator pedal and the brakes are just the brakes. This system has several advantages: 1) The brake control system can be much simpler. 2) You get almost one pedal driving. 3) There is no transition feel (which feels like your brakes have gone) because the system has decided to stop regeneration. This happens on expansion joints and rough surfaces while braking in non-Tesla cars with regen.Can you be more specific where to find data on regenerative braking? Also in general.
Especially considering that those are pretty mighty big disks the Model S is featuring on all four wheels...
Has Tesla published data defining how much energy (or miles) are generated via regenerative braking? I’m interested if my dogmatic focus on optimize regenerative braking makes a material difference.
I would really like to know how many kWh are gained by regeneration.
The electricity gained by regeneration goes right back to the battery. So this contributes to the cycling of the battery.
I'll share my conclusion: regenerative braking is a waste of energy that would have been better conserved by not having to slow down in the first place, I.e. the best power consumption target is flat. Regenerate nothing, and don't use the brakes. I wish I could turn regen completely off on the highway, but at best I can only turn it to low. I view each use of the brakes as a failure, bad planning on my part. Except of course, when you need to use the brakes.
There is a meter on my car, a green arc that shows how much juice is being generated in the moment.
And on the trip meter consumption graph, the area under the chart, where it goes green shows what you've packed back in over time... dont all S's have this?
Take a trip up a big mountain range, then back down... the same route.
Don't touch the brakes on the way down. Nor the accelerator.
Go as far as the car will by coasting to a stop at the bottom.
Note the total distance travelled. And energy used.
Observe the SOC, at the outset, at the top, at the bottom after the return trip.
Repeat, but this time turn regen setting to low.
Finally, find a nice flat stretch and drive the distance obtained above, at the average speed it took you to do the round trip. And for good measure, drive back on the flat route that distance again to rule out wind and altitude.
Draw your conclusions, and share with the group here.
For me, the massive brakes on the car are mostly wasted, but there when needed because the car is so heavy. The regenerative technology is also mostly wasted, my commute is highway. But the regen is free, doesn't add weight, and is better than fricton braking when you do need to slow down - so I'll take it. Dont forget regen is still braking, which is a waste.
I can answer your question quite precisely. I use a programme called linkmytesla. It shows you how much energy is regenerated and over the last 24.000 km I have regenerated 17% of the total energy consumption. In genereal this value will be between 15-20 % depending on driving habits if you keep regen in standard mode.
Thank you very much. This is what I was after.
So the Model S uses 17 % more electricity for propulsion than the power meter will tell us. But this electricity is produced in the drive train. Clever.
The batteries are charged and discharged more than most people might believe. No measurable degrading because of the small amount of charging.
Thanks everyone. So, no general statistics. Regen is very much dependent on the way you drive and tend to come to a halt.
