I put together a little DIY to resolve the Creaking & Squeaking of the upper control arms. Low cost, less than $30 first time and then about $0.25 each time after (if your jumping in to this without a grease gun).
Should take you just a couple minutes to do. In most cases no need to pull the wheels off, especially if you have air suspension, just raise it to max. Though if you want to pull the wheels off, you can also inspect the other suspension components.
