I'm part of an SGIP program with SCE in Southern California. We have a small (3kW) PV system and a single Powerwall 2. We don't have an EV or AC. On sunny days the system meets about 75% of our power needs in winter, and 100% in summer. We live near the coast, so are subject to foggy mornings from about April through August.
My question has to do with optimizing the switch between Time-Based and Self-Powered control. Is there a way to do that programmatically?
On sunny days, it makes sense to keep our system in Self-Powered mode. We generate enough power to both charge the battery and run the house. When peak rate time arrives, the battery is at 100% and we haven't used any utility power. If it's cloudy and the PV system is under performing, then TOU mode is the right setting. That assures the battery stores as much power as possible ahead of peak rate time.
I'm wondering if there's a way to write a control system that does this sort of switching automatically. That would just be a fun exercise at this point, but could be quite important if the PUC proposal goes through. As i understand that proposal it: a) cuts our compensation for power fed back to the grid to wholesale rate (~$0.05 / kWh), and b) increases peak rate for customers with PV systems to $0.48 / kWh). If this goes through, it won't make much "cents" to sell power to SCE, and will be even more important to not use peak rate electricity. Hence the interest in a way to optimize the mode switching that would accomplish this.
Also wondering if maybe Tesla is working on something along these lines. They already incorporate weather with Storm Watch.
