Why not go there? I'm generating the power to charge my Roadster by spinning a 3-phase motor. By experimenting with multiple capacitors I was able to convert it to single phase. It's only about 85% efficient but relatively cheap. OK, I confess it's not very portable!No you've pretty much summarised it.
If we could get one phase from the plug it would be better than nothing. To use all three phases in balance would require a rectifier-inverter (or a rotary converter but let's not go there).
It's hard to know how big a rotary system of that capacity would be. The converter is theoretically not consuming much power.Yeah I was thinking about the portability angle. How easily would a 16kW unit fit in the trunk?
Yes a pain - pay $600 for a spare mobile adapter; drill and tap the end piece for a larger strain relief; drill out the spacers in the crimp sleeves to accommodate heavier gauge wire. Do you have a reasonable source for the M plug? Yes a pain but at least then you can travel.If you were able to take 32A from one of these posts then it would be 7kW. Not great but not bad either. The spec allows for 70A on one phase but no one has implemented it yet that I am aware of.
We haven't tried it as getting the Tesla connector is a pain, but I think that is what EV Box have done (by butchering a cheap cable).
You didn't really answer my question. Would 100 people buy them at 600 EUR? or 10? They would be 70A capable....
We had a discussion about a group buy. I think $750 would be acceptable.
