Converted Lotus Elises - ECE, Detroit Electric
Discussion in 'Electric Conversions' started by doug, Jun 24, 2008.
  1. malcolm
    malcolm Active Member
  2. graham
    graham Active Member
    Aptos, California
    Detroit Electric makes an electric Elise?
    Alternative Energy: Driving The Detroit Electric Lotus Elise And Proton Persona
  3. JRP3
    JRP3 Hyperactive Member
    Central New York
  4. vfx
    vfx Well-Known Member
    CA CA
    "We are very proud of our tulips, our windmills and our wooden shoes, but we are more than that."
  5. stopcrazypp
    stopcrazypp Well-Known Member
    #6 stopcrazypp, Sep 3, 2008
    Here's another:
    DRIVEN: Detroit Electric’s electric Lotus Elise
    Let's see the specs:
    Based on the Lotus Elise
    150kW (200hp) motor
    0-100km/h (0-62mph) in 4.3 seconds
    220km/h (137 mph) top speed
    325km (202 mile) range
    200,000km (124k miles) expected life of battery
    Hmm, what car does that sound like?
    Edit: Ironically, after watching the videos, I noticed the car literally sounded exactly the same as the Tesla Roadster.
    240v 10A charges it in 6.5 hours. (fishy numbers 240*10*6.5 = 15.6kWh, should be impossible to travel 200 miles with just 15.6kWh, that's just 78Wh/mi)
    240v 35A in 3.5 hours. (This one gets 240*35*3.5=29.4kWh, bit more believable)
    240v 100A charges it to 80% in 10-15 minutes.
    The engineer claims his motor is revolutionary because it is it makes 5kW per kg, while typical motors make 0.25kW per kg. The Tesla's motor makes a peak of at least 250hp=186kW, weights ~70lbs=32kg, so 5.8kW per kg.
    Anyways perhaps this will be a less expensive version of the Tesla Roadster.
    Edit: An interesting point is the electric Lotus Elise prototype seems to have kept the standard transmission from the original Elise. There is a clutch and at least three gears (I assume it has 5 gears, but the author only talked about shifting to third gear). I wonder how long a standard gearbox will last used this way.
  6. doug
    doug Administrator / Head Moderator
    I merged this thread with an older one that has a link to some videos that are probably worth watching again.
  7. graham
    Aptos, California
    Sorry doug! I guess I missed/forgot about this thread!
    Thanks for cleaning up after me!
  8. vfx
    CA CA
    #9 vfx, Nov 24, 2008
    Detroit Electric returns
    Can't belive we have not discussed this company's rebirth here yet. [Edit: Turns out this entire thread never mentioned my search term "Detroit Electric"]
    This post puts them in Tesla territory.
    From Martin's Blog (fridge page)
  9. graham
    Aptos, California
    Isn't Detroit Electric now just another name for Zap and their Chinese partner?
  10. domenick
    domenick Nerd
    Florida
    Zap! and Youngman both gave up their ownership. There may still be some contractual obligations though.
    Detroit Electric hooked up the Electric Cars Europe and Proton. It's a difficult tale to follow and I don't really "get" it. Martin would surely add some credibility to the venture.
  11. vfx
    CA CA
    I'm famous! (in an incestual way) :redface:
  12. vfx
    CA CA
  13. JRP3
    Central New York
    My guess:
    200km range
    150kw peak power
    0-100kmh less than 5 sec
    Top speed 215 km/h
    10 hour recharge at 16 amps
    4 hour recharge at 32 amps
    Price: €128.750
    So it's not as good as a Roadster but a lot more expensive. Unless "Versnellingen" is something really cool :wink:
  14. dpeilow
    dpeilow Moderator
    Winchester, UK
    ^ Gears. 3 + 1
  15. TEG
    TEG TMC Moderator
    And another:
    Press releases - E-world energy & water
    2009
    http://www.kom-strom.de/get.php?f=864e3a8e3955175636ca8f328a8eb2f5.pdf&m=download&session=4bb02b2db0d50419d61c8707ea200ff2&dl=1
  16. TEG
    TEG TMC Moderator
  17. TEG
    TEG TMC Moderator
    innosysengineering.com Home
  18. dpeilow
    dpeilow Moderator
    Winchester, UK
    This one is not really "charging" (the charge posts appear not to be wired in) but infact is being used as a giant videogame controller. It is a real car though.
