Converted Nissan EV cause of fire onboard "Pearl of Scandinavia"
Discussion in 'Electric Conversions' started by Mark Petersen, Nov 17, 2010.
Tags:
  1. dpeilow
    dpeilow Moderator
    Winchester, UK
    No - after the initial reply
    I asked what type of socket they had and then got this
    Which implies it is at the discretion of the ship's crew, or more likely the crew knew more about the situation than their customer service agents...
    Don't forget it was a DFDS ship that had the fire in the first place.
  2. dpeilow
    dpeilow Moderator
    Winchester, UK
    I've just been chatting with the captain of the Stena Navigator. Thanks to the ship's satellite internet link I was able to show him this thread mid crossing :smile:
    He (and other crew) are totally on our side on this issue - they appreciate the difference between a factory EV and poorly engineered conversion. I have a name to contact in HQ. Maybe there is hope...
  3. vfx
    vfx Well-Known Member
    CA CA
    Dave is on fire this month!
  4. dpeilow
    dpeilow Moderator
    Winchester, UK
    Let's hope not, I'm on another ferry tomorrow morning...
  5. dpeilow
    dpeilow Moderator
    Winchester, UK
    Currently charging the Roadster on the Ulysses. We had some fun and games to get it up and running but got there in the end.
    When I drove onto the ship, of course the crew were not even aware they had an EV charging station on board! I was directed to the wrong deck. The EVSE is J1772 anyway.
    I then tried to connect it up to one of the sockets that is provided for reefer trailers. No joy - they don't wire the neutral pin.
    Eventually we got charging on 13A. The crew were really helpful and the ship's electricians were really pleased to hear from an EV driver what we need for the future. I gave them a 32A socket that I had in the car to install for others on future trips.
  6. Eberhard
    Eberhard #421 Model S #S32
    Germany
    I did charge my Tesla on my trip from harwich to hook van Holland. I was offered a 32A but it did not work. someone said here on the forum, that there is no neutral pin weired. i assumed, that the 60Hz may be the reason. But i was able to charge with 16A. If an extension cord is used, then it must have at least 2,5 sqmm and the spare cord not being put on the drum. 1,5 sqmm is ok only for 10A.
  7. TEG
    TEG TMC Moderator
    On a European vessel?
    http://en.wikipedia.org/wiki/SAE_J1772
    http://www.sae.org/mags/sve/NEWS/8862
  8. dpeilow
    dpeilow Moderator
    Winchester, UK
    Our Nissan Leafs and i-MiEVs have it. It's VHS vs Betamax again.
  9. Eberhard
    Germany
    J1772 may only useful, where one-phase is available. this is not true in Europe. we have 3-phase. I have in my garage 400V/32A and can charge on only 1/3 of my possible load. This means i have to wait 7 hours for full charge instead of 2.5 hour. Only DC-charging (level 3) can be an international standard. Model S can do 480V with internal charger. Then i can charge with about 14kW, whats better then the current 7kW with my roadster but still less then 22kW being possible.
  10. AndrewBissell
    AndrewBissell Member
    Eberhard
    Actually it's even more complicated! Europe is split between countries where 3-phase to the home is common (e.g. Germany) and those where each home is typically on a single phase circuit (e.g. Britain).
    However, I completely support the idea that three-phase charging needs to be supported by the vehicle's on-board charger.
    Unfortunately DC fast charge is very expensive to implement, but it will be very important along autobahns.
    TEG
    It's more complicated too!
    J1772 is as I understand it as much a signalling protocol as a connector. There is a connector profile (the SAE one) for single phase up to 70A used in Japan, USA and Europe (for Leaf and iMiev) and a different one (the Mennekes one) promoted largely for Europe that allows either single or 3-phase charging from the same EVSE (up to 63A 3-phase or 70A single phase afaik).
    Whereas the SAE profile fixes the cable and connector to the EVSE, the Mennekes one offers a socket on the EVSE. The driver carries a cable with connectors both ends. The cable can be either Mennekes to Mennekes or Mennekes to SAE. In principle (and I believe RWE built some in practice) a Mennekes to Tesla cable will work. So a Mennekes unit in Europe can support a Leaf, iMiev, Tesla (single-phase up to 70A) and a Renault Fluence (3-phase 32A) or Renault Zoe (3-phase 64A).
    So maybe we in Europe can end up in a slightly better than betamax vs VHS world, but only if EVSE makers pull their fingers out and deliver on this promise before a huge plethora of SAE profile stations get implemented by default.
    Best regards
    Andrew
  11. zeroemissioncruzer
    zeroemissioncruzer New Member
    Yeah right...
    This type of cover-up is a set back to ev safety progress. AFuture needs to explain in detail what event caused this fire, be honest. It wasn't the plug, the cord or the mismatch of the ships power (circuit breaker protection). The car obviously over-charged, most likely due to improper charger parameters.
  12. JRP3
    JRP3 Hyperactive Member
    Central New York
    Jack Rickard of EVTV speculates that a faulty Battery Management System failed to shut down the Brusa Charger, which is an expensive well controlled unit on it's own, unless a BMS connected through the CAN bus takes over and makes it dumb. Of course Jack thinks every EV fire is the result of a BMS....
  13. Mark Petersen
    Mark Petersen Model S EU P71
    Hørsholm, Denmark
  14. dpeilow
    dpeilow Moderator
    Winchester, UK
    This appears to be a Roadster charging on the Harwich-Hook of Holland ferry on Feb 9th. So some are getting away with it despite the supposed ban!
    Remotion Tesla op de boot naar UK on Twitpic
    There was an new owner that was intending to take his car to Germany this way too. I hope they allowed him to charge.
  15. doug
    doug Administrator / Head Moderator
    Either way, that's very bad news for the company that did the conversion. Are they still in business?? Their website seems to no longer exist.
    Domain afutureev.com hosted by DanDomain - www.dandomain.dk
  16. Fuzzylogic
    Fuzzylogic EU Sport 359 & S94
    The Netherlands
  17. Mark Petersen
    Hørsholm, Denmark
    hi
    yes Afuture.dk closed up shop some time last year
    as the business case suffered from to much bad press
    and with the new information, it kind of sound like they tried to blame the home made cable
    in an attempt to move focus away from the bad design of there battery pack
  18. domenick
    domenick Nerd
    Florida
    I can't help but wonder if it wasn't a matter of condensation shorting out BMS wires. The Racing Green Endurance team had a fire they attributed to that. Luckily, they were right there when the fire started and able to put it out before it destroyed their car. It happened in Columbia after they removed the car from its (presumably less humid) shipping container.
  19. dpeilow
    dpeilow Moderator
    Winchester, UK
    Just had confirmation from a dutch Leaf owner that he was able to charge at 16A with a CEE plug on the P&O Ferries Europoort (Rotterdam) to Hull route. That's interesting because when I wrote to P&O back in January they said it wasn't possible. Maybe this prompted a change of heart.
    If any dutch Roadster owners fancy coming over to the UK for a tour, Hull is within easy driving range of the Nottingham HPC.
    Here's the car in England's Peak District:
