Coolant pump running all night
asgard
310
9
Hi folks:
It's pretty hot in my garage (95+ F) and the coolant pump in my Roadster ran all night and is still running. Is that normal?
Thanks.
dhrivnak
4,389
3,516
NE Tennessee
Very possibly, as I know my pump runs MUCH more when it is warm. And I am fortunately that my garage rarely gets above 80. Not sure if the exact temperature but any time the pack is above say 130 the pump will be on.
gregd
2,524
1,755
CM98
Hi folks:
Thanks.
Seems to be. Mine ran for a couple of days last week after driving home, uphill, in mid-90's afternoon heat. I didn't think the ESS would be so well insulated or thermally massive that it would stay that warm for that long, but it kept humming. Next time I took the car to work (and a standard charge), upon returning home I gave it about an hour's charge at 240v, 24A, in RANGE mode, then stopped it. The end result was a pack with slightly less than a full STANDARD mode charge, and because the Range charge puts priority on cooling the pack first, when I unplugged everything, the pump turned off too. Yea!
sethr
CPO Roadster #1089
Mar 24, 2013
255
150
Fairfax, VA
The pump will stop running when the battery gets below 31 degrees C. (There is mention of this temperature buried in some thread that I saw a while ago.) I was having the same issue, and when I saw the temp. was at 32, I charged a bit more at low amperage, (just a couple miles worth), which got the pack down to 30, and presto, the pump turned off.
evsolarman
30
0
United States
My pump was running for a long time.. the i realized one of the back doors was not closed properly..
Rik
142
0
Northern VA
My pump would run 24x7 off and on. Sometimes the temperature would be warm enough to warrant it, however, I have found that my driver side outer taillight would be dimly lit in my garage when the car is off. Rockville SC shrugged it off last Fall. Tysons SC shrugged it off last week until I heavily influenced the techs to cup their hands around their eyes and the light to see the dim glow. They saw it and after 5 days of troubleshooting and part ordering, the answer is a new taillight. Heard a special Roadster tech from Jersey came down to Tysons and within minutes said "order a new taillight".
Longwinded way of sharing that my pump had been running continuously on days when my taillight was faulting.
