Background:
I am on PG&E TOU-B (peak 3p-9p M-F, all other times off peak)
I have a 12.6 kW (DC) PV (majority of my panels facing west) and 3 PW2. Currently set to Time Based Control / Balanced with a 15% reserve.
I have a two story home with old (2005) AC units. My home office has a 5500 btu/hr unit that vents to a window. Draws about 950 w.
(We have NG Dryer, Furnace, Stove/Oven, water heater)
I have been effectively off-grid since February with only a handful of days where I have needed any significant grid draw.
February: 719 kWh usage / 1066 kWh PV
March: 863 kWh usage / 1523 kWh PV
April: 835 kWh usage / 1884 kWh PV
This will flip eventually where We will see days needing 80 - 100 kWh and only producing 75 kWh (last year underperformed so I'm guessing here).
Situation / Question:
May is the beginning of Air Conditioner season for us. I use a whole house fan to try to cool the home as much as possible first thing in the morning.
If I leave the ACs off in the unoccupied areas of the house (everything except my home office until school is out for the summer) The 2nd story ends up being pretty hot by the time the kids need to go to bed. This means the AC is running pretty hard during peak times. PV is exporting and the PW are running the house.
You will see in these two screenshots that on May 3rd I let the thermostats run normally where the AC doesn't kick on until close to when we need to go upstairs for bedtime.
Yesterday, I tried "pre-cooling" by turning the thermostats down right after the PW reached 100% charged.
I also am currently running my pool pump during the day, it doesn't start until I know the PV will be higher than total home load.
Should I be trying to use directly as much PV as possible to avoid efficiency penalties (90% round trip)?
Does this only matter until I reach a point when my PV produces less than my daily usage?
My home doesn't have great insulation so I'm wondering if the 10% efficiency gained from not doing the round trip would be wiped out by cooling the upstairs earlier than needed.
What would you do? Set it and forget it? Or try to manage it more actively?
