Preamble On Edit: As previously suggested, I have created this new thread, carving out from the main 'Coronavirus' thread the initial responses.
ON UV SANITIZATION
I have seen reference from some of you in this thread regarding UV-C lights as being an effective sanitizer. I consider this an appropriate topic for this thread and would like to encourage it - whether the premise be correct or incorrect. (and if it is correct and the subtopic has legs, I may spin it out as a separate thread).
My overnight thoughts are the following:
Questions that immediately come to mind:
(No longer needed)===> ON EDIT: PLEASE make use of "ON UV SANITIZATION" etc., as the first words in any response to facilitate any porting-over to a new subthread were that to occur. Thank you. <===
ON UV SANITIZATION
- build a light-proof box large enough to handle the single largest item I consider it likely to come to our household.
- 1m x 1m x 1.5m is what I have in mind.
- surround interior with reflective surface.
- Need it be glass mirrored, or would aluminum foil suffice?
- Place UV-C source at one corner
- Have a suspension in center of box top for item to be sanitized
- Hook and a cord that one pre-winds prior to emplacing in box, so that it turns
- alternative, just a little more work, would be to have some kind of rotating mechanism through the top, crank-turned
- Hook can be augmented with or replaced by
- a clip for such items (like bag of frozen goods, etc.) not suitable for hook
- a "toaster carrier" type of gadget in order to hold multiple items like mail
- other?????
- Light switch is outside of box
- Most simple is to keep cord unattached to receptacle except when used
- In-line switch next simplest
- Box-mounted switch marginally more professional
- Dead-man safety switch doubling to lid being affixed or not is a very good idea. Plunge-type would suffice.
- How best to ensure light really is on?
- A light "weep-hole" a very safe distance from the ground - 1" would do - that can shine only downward?
- On to what kind of surface can one safely project UV-C rays without the reflected rays being dangerous? Mere white paper????
- An in-line ammeter will demonstrate whether there is demand for electricity - ie, whether or not the light is functioning. This would be appropriate only if there is no electric draw other than the UV-emitter itself: motorized turner, static transformer, etc.
- A quick web search using ONLY articles that appeared BEFORE Dec. 2019 suggests that broad-spectrum UV (200-400nm) is at least as effective as UV-C (222nm or so), and that UV-C preferences have appeared as a way to reduce the concomitant damage to living tissue. Ref. e.g. Can UV Light Fight the Spread of Influenza? , and esp. Far-UVC light: A new tool to control the spread of airborne-mediated microbial diseases
- True or False?
- How long for appropriate exposure?
- What effects might it have on foodstuffs? Is this a concern, or can one reasonably assume that ex-vivo exposure time from any contaminated food, as opposed to its packaging, is all that is necessary?
- Regarding another's posting that s/he plans to sanitize an n95 mask for multiple re-use with UV-C: I suggest be very careful with the deterioration effects of UV on elastic. My lifelong experience with rubber bands is that sunlight destroy them pretty quickly and first suspect is its UV rays. So check to see that any mask's bands remain pliant, or else.....
(No longer needed)
