Varies by climate and location and whether regular 'clean & lube' maintenance was done. Had mine done a few days ago and skipped a couple years. Fronts were not sliding well on the pins and 'shelf' they sit on so they were wearing faster and more uneven than expected. Also inside vs outside pads were a little different. I was able to see this with my own eyes as I talked with the mobile tech (non-Tesla) as he took them off with some difficulty because of them not sliding and be 'jambed'.The brake pads and rotors should go for a very long distance because of regen, 100,000+ miles. The fluid flush should be under $150. The brakes are Brembo, so a standard high-performance brand.
One of the "bad" things about regen braking is you don't use your disk brakes often so they develop rust on rotors and they can make screeching/scraping noises from lack of use. Unlike ICE vehicles where they knock any rust that builds off the rotors when they make a couple of stops. Also, as you point out, the caliper pins develop corrosion and get stuck. And then when you do press on the brakes the pads don't slide as easily. We used to always put lithium grease on the pins at each pad/rotor change. But, with EVs that make be hundreds of thousands of miles apart instead of tens of thousands. Stil,l I will take the regen and deal with these minor brake maintenance issues.Varies by climate and location and whether regular 'clean & lube' maintenance was done. Had mine done a few days ago and skipped a couple years. Fronts were not sliding well on the pins and 'shelf' they sit on so they were wearing faster and more uneven than expected. Also inside vs outside pads were a little different. I was able to see this with my own eyes as I talked with the mobile tech (non-Tesla) as he took them off with some difficulty because of them not sliding and be 'jambed'.
In wet areas, there is a little more rust/corrosion if the physical brakes are not used (not heating up and self-cleaning) and regen is mostly doing the work.
any *reputable* shop can do your brakes. if you're going to a shop, just know it's typically bad form to bring your own parts. however, these should be a good reference for *just* partsHow much does Tesla quote for a front brake pads and rotors replacement with fluid flush?
Anybody in the Raleigh area that can do this apart from Tesla?
I had front and back done last year. Looking at my invoice, it was $725 for the front pads and rotors. It doesn’t say whether or not a fluid flush was done, however.How much does Tesla quote for a front brake pads and rotors replacement with fluid flush?
When I had a mobile tech (not Tesla's) come do my clean and lube he actually did two separate tests of my fluid. One tested for moisture and the other tested for things like copper. From something I read:It doesn’t say whether or not a fluid flush was done, however.
The manufacturer says testing for copper is much more important and is a more reliable indicator of corrosion, and that moisture is basically a non-issue in modern brake systems. The copper contamination comes from the copper coating on the inside of brake lines. When the corrosion inhibitors in the brake fluid wear out, copper starts showing up in the fluid (supposedly).
no need to overthink brake fluid. change it once a year and call it a day. the main issue with brake fluid is that it is hygroscopic and will absorb moisture. when water boils you get air in your brake lines and the it leads to overall negative feel/performance. the boiling is less of an issue if you don't use brakes, but, it will still pull moisture.
My impression is they are coming from a "racing" or driving your traditional car very hard background .... that is to say not taking into account the amount of "braking" that is done by the regen (motors) electric braking vs the physical braking system (pads/fluids/etc).Changing brake fluid once a year is overthinking and completely not necessary. Money waste....
I agree. A brake fluid replacement is a pretty simple operation and relatively cheap. And the downside of having water in the fluid is increased stopping distance and potential corrosion of the brake lines, hoses fittings, and pistons. All of which can be an expensive repair.ok, then don't. a properly bled brake system will feel and perform better than one that hasn't been maintained. at the end of the day your brake fluid is absorbing moisture whether you use them or not
Congrats on the "newer" X! Curious: How many miles did you have on the 90D when they did the front brakes?Quick update: Got it done from Tesla Raleigh service center for $1,200. Front brake pads, rotors and brake fluid flush. Also, sold the MX 90D right after and got a 2018 MX 100D!! loving the new ride with the 60 mile additional range and MCU 2!!
122,000Congrats on the "newer" X! Curious: How many miles did you have on the 90D when they did the front brakes?
Ha. Wow; mine needed them replaced 90,000 miles less than that. That's how badly the previous owner abused this car.122,000
Using brakes is not "abusing" your carHa. Wow; mine needed them replaced 90,000 miles less than that. That's how badly the previous owner abused this car.
Needing a brake job at 27k miles on an EV with regenerative braking due to lack of proper usage or maintenance to them, opening both front doors into brick or stone walls and chipping the paint off the edges of both, scratching the inside rear interior by not properly securing a load, and climbing in and out of the back of the car with biking or baseball cleats on (marring the skid plates) is not exactly my idea of taking proper care of your automobile. Please reply with the proper term I should have used here...Using brakes is not "abusing" your car![]()
