I pay .07997 perkw. Cost 31cents to drive to work each way according to Teslafi.
I just show people my Teslafi screen and watch the wheels spin in their minds.
Who pays this for Electricity, Never have I ever read so much FUD in such a short space, haha!I pay approximately (it varies with amount used and the seasons) $1.16
per kwh.
Someone should inform this guy of a new piece of technology known as the clock. It allows EVs to charge at night when residential load is low.This is the elephant in the room with electric vehicles. Our
residential infrastructure cannot bear the load.
LOL. My 50-amp circuit for my NEMA 14-50 charger that only draws between 12-5am suffices just fine, along with my 200 amp service.When you see this just smile...
...For example, a home charging system for a Tesla requires 75 amp service. The average house is equipped with 100 amp service.
You picked the wrong electric provider. I pay $0.091 per kWh. Which is more typical. So 63 kWh x $0.091 = $5.73 => 1.91 gal
Then 250 miles / 1.91 gal = 130.89 empg. Even in Hawaii I only have to pay $0.152 per kWh. $0.27 is ridiculous.
GluttonLOL. My 50-amp circuit for my NEMA 14-50 charger that only draws between 12-5am suffices just fine, along with my 200 amp service.
And charging losses, I typically get 94% charging efficiency per TeslaFi, not sure how accurate this is as I have read that it could be closer to 88%, does anyone know what is typical?My local utility charges about 10 cents a kWh, so about 2.5 US cents a mile excluding vampire losses.
<snip>
My response using actual data:
The Tesla is great to drive. But, your calculation’s are still messed up.
Electricity to go 100 miles is 25 kWh or 25 X 0.091 = $2.28.
Gas at 25 mpg (my Lexus) at 2.119 per gallon = 4 gallons for 100 miles or $8.48
Plus I don't pay for oil changes or a dozen other expenses you pay for with in internal combustion engine.
The average is about $3,400 a year.
There is some small maintenance. About $475 a year. Now tires are expensive because you have to have
a tire that can go the 155 mph top speed of the car. But an Audi or BMW or equally fast internal combustion
engine car would require the same expensive tires. Also the Audi or BMW requires Premium gas at $2.799
a gallon so the cost for a “comparable car” would be $11.20. And these “comparable” cars costs as much as
a Tesla.
The IRS gives you $0.55 per mile to drive a car. That’s closer to the actual cost.
So I got the car in November. So October with no Tesla was 1,544 kW
November was 1,456 kWh and about 1,400 kWh after the Tesla The year before with no Tesla was just over
1,000 kWh during the winter. So it looks like 400 kWh per month for the Tesla, or $36.40 But gas would have been
$135.04.
Well it all depends on where you live, I have a TOU plan here is Southern, CA that is $0.12 to $0.13 starting at 10 pm to 8 am but SCE is changing the rate plan and by fall of next year my rate is going up, My brother has PG&E in Northern, CA and his cheapest rate is $0.22 still I have read of people having deals where it is under $0.02 or even free during certain hours.
You lose.
Bad cost calculations aren't the point of articles like that. They are articles that throw a load of mud at the wall to try and get as much to stick as possible.
If you're going to address those articles, go through clearly, point by point to try to clean it up.
Included. My lifetime (June to March, so far) battery to wheels is 217 Wh/mile. I figure up to 12% charging losses so 217/0.88 = 247 Wh/mile meter to wheels.And charging losses, I typically get 94% charging efficiency per TeslaFi, not sure how accurate this is as I have read that it could be closer to 88%, does anyone know what is typical?
Because everyone's ice cars are different and electricity costs are different it's hard to compare. All I can say is that i was averaging $145/month in gas and now instead of that my PG&E bill rose $45/month.A question I'm asked every time I tell someone I've gone electric, is "how much does it cost vs a gas car?" Of course this isn't a simple answer, given all the variables involved. But I've honed it down to a short quick answer. "About half of what gasoline costs". The formula I use is as follows, using round #'s.
Assumptions: 1. cost of gas: $3/gal, 2. cost of Kwh: .27cents (PG&E, Marin Co, SF Bay Area), 3. miles per KwH: 4 (300 mile range on 75 KwH batt pack: M3, LR, AWD) 4. Avg mpg of gas car: 25 mpg.
Example: 250 mile trip, gas vs elec.
Electric takes 63KwH to drive 250 miles (250/4). 63 x .27 = $17
Gas car takes 10 Gal to drive 250 mi. (250/25). 10 x $3.00-$30
Now, I know there are other benefits of driving electric, but most folks look at the bottom line before anything else, so am hoping to open some minds to going electric. The other surprising number to come out of this, for me at least, is my equivalent mpg. If driving 250 miles costs me $17, that's the same as using 5.67 gallons of gas. 250 miles / 5.67 = 44 mpg. The sticker MPGe says I should get 116 MPGe. Not sure how the EPA/DOT got 116, but either my or their numbers are way off. Thx for reading. Feedback welcome.
