The use of energy to heat the car is not shameful, it's simply physics, and the use of a Positive Temp Coefficient resistive heating element.
The purpose of this thread is to compare the cost of running a Tesla to running a gas car. It's AWESOME to be able to preheat the Tesla easily, and it is much better than freezing in an ICE car until the engine warms up. But it comes at a cost (as does preheating an ICE car if you choose to do so).
As the purpose of this thread is to compare to ICE costs, where it is
easy to calculate the total fuel used, I simply was stating that to properly assess the energy used by the Tesla, you have to look at the
integrated draw from the wall,
not look at the meter in the car, etc. There are simply too many variables for an individual user that that is the only way to be accurate. It's really the ONLY way to compare the costs, if that is your SOLE objective. And I provided some APPROXIMATE numbers to give people an order of magnitude they could have in their head for the costs of certain activities, since most people
cannot accurately meter their EV energy usage in isolation - my estimates are not set in stone, but I have proven that my numbers are 100%
conceivable. Will the actual number USUALLY be closer to 1kWh for a 15-30 minute preheat? Of course! That was clear from my earlier statements!
Look, I love my Tesla, I repeat, I LOVE it. But it's not like it is God's gift to man.
If I lived in an EXTREMELY cold place it would be quite easy to prove the 5kWh number is in the ballpark. Should I have said 4kWh? Maybe...not really the point. Why anyone would do a 30-minute preheat, who knows, but that's also not the point (30 minutes wasn't my number). Charging the battery??? The 12V? Do you have a wattage for that? My estimate is that it takes less than 200W and probably closer to 100W to do that - but the question is really the integrated energy that would need to be added, and since we know vampire is about 750Wh/day, a cycle of charging of the 12V is likely considerably less than 250Wh (I think it's likely less than 100Wh since the total vampire drain per day is dominated by
other losses (windshield cam heater, cameras, ultrasonics, computer, etc.) during the period of time the car is in idle mode, not while it is in sleep (when it is draining the 12V)).
Much more likely, in a cold, cold place, you're going to see the 8.5kW from the wall for the heater, plus an additional 2kW (scaled up to 2.4kW from the wall), plus seat heaters (let's say 2, for a total of 200W - this is slightly high but maybe not too far off when scaled up to the AC power requirement), so that leaves you at close to 11kW.
@eprosenx has measured what he saw over the winter during a preheat as I recall.
In MOST cases, of COURSE it would taper down the heat as the cabin came to temperature. But not so sure how much tapering there would be when it's -20 degrees out. I KNOW it tapers to 1.6-2kW for a 12 degree F
difference from ambient (72F vs. exterior 60F). I imagine to maintain a toasty cabin temperature when there is a 100 degree differential the tapering will be considerably less! Plus the battery heater will likely be operating for quite some time at 2kW at -20F, since 1000 pounds of battery & coolant has a lot more heat capacity than the dry air in a cabin. So that's 1.2kWh JUST from the battery heater.
