Cost of model s charge port replacement?
Discussion in 'Model S' started by ericscottf, Dec 15, 2017.
Tags:
  1. ericscottf
    ericscottf Member
    NY Metro area
    So my car slid down the driveway while plugged in today. Wall charger cable ripped out where the cable meets the wall and shut down admirably. No sparks or drama. Good job engineers!
    Charge port is cracked internally. I was lucky to get the cable out after several tries, otherwise I would have had to get towed at the bottom of my driveway... Car drives and behaves fine otherwise.
    Anyone know what the approximate cost to replace a charge port on the car is? And whether or not this is a quick fix at the service center?
  2. Tam
    Tam Well-Known Member
    Visalia, CA
    It should be quick and easy to replace a charge port. It's about $600 last year.
    • Informative x 2
  3. ericscottf
    ericscottf Member
    NY Metro area
    I would consider that a cheap price for a lesson learned... I'll be stoked if they can do it in a day or less...
    I was just about to brag about how great it handled in the snow.. going places other cars were turning around from, with ease!
    This driveway is really slanted - I knew it was possible to slide, and i typically bounce around in the car after parking to make sure it's secure... I guess I didn't bounce enough this time. At least nobody was behind it!
  4. Tam
    Visalia, CA
    How won't it slide down again?
  5. Chaserr
    Chaserr Hyperactive Hyperdrive
    Logan
    Probably snow, his profile says NY
  6. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County, Virginia
  7. ericscottf
    ericscottf Member
    NY Metro area
    I'll be less confident that it can stay parked on snow - and shovel/salt before parking it in the future... 10 minutes of shoveling would have saved me what will probably amount to the better part of the day(if I'm lucky) between getting the car in for repair and repairing or replacing the wall charger...
  8. David99
    David99 Active Member
    Brea, Orange County
    Please let us know how much parts and labor was when you get it fixed.
  9. Vip
    Vip Member
    United States
    I can tell you that it takes literally less than 10 minutes to swap it out. Tesla replaced mine under warranty because the magnet failed to keep the charge port shut.
    I watched them do it. A couple of screws and a wire connector is all that is keeping it in place.
    Mine is is a 2013 so things could have changed.
  10. Dborn
    Dborn Confirmed
    Sydney, Australia
    I wonder if the old charge port can be replaced with the new automatic closing unit?
  11. FlatSix911
    FlatSix911 Porsche 918 Hybrid
    Silicon Valley
    Much cheaper as a DIY project ... :cool:
    US $79.99 Tesla Model S OEM Charger Charge Port Socket Inlet Assembly 1005612-00 | eBay
    US $99.99 Tesla Model S OEM Charger Charge Port Socket Inlet Assembly 1005612-00 1005613-0 | eBay
    US $98.95 New TESLA MODEL S EV CHARGE PORT ASSEMBLY OEM 1026041-00-M | eBay
  12. David99
    Brea, Orange County
    I asked the service center and they said no. They are different size. I also remember Jason Hughes mention it in a post here. He tried but it didn't fit.
  13. ericscottf
    ericscottf Member
    NY Metro area
    Update for those interested... Called my service center this morning and got it in at 9am. They replaced the port and cleaned the car... 550 port, 150 labor. Got it back a few hrs later. They were super cool about it and didn't make fun of me.
    • Like x 4
  14. ai4px
    ai4px Wes
    Sumter SC USA
    I have to wonder if you could pour a little concrete hump on your driveway that would serve as a wheel chock? Maybe one on each side?
  15. nitrous
    nitrous Member
    Hamilton
    has happened to me twice. first time, just tore the black plastic end of the charger wand off. No damage to the charge port. Second time, it destroyed the charger wand again ($500 a pop) AND bent the door back far enough to break the red plastic reflector.
    I'm told that the model S from 2016 onward are more complicated in terms of remove/replace. All the trunk liner on the drivers side needs to be removed. It's said that this is NOT a user serviceable part because you have to remove a high voltage line. The tech told me not to worry about it.
    Pretty expensive slope, we have on our driveways!
  16. tdbostic
    tdbostic Member
    El Paso
  17. nomis_nehc
    nomis_nehc Member
    Rancho Cucamonga
    My 2018's charge port randomly wouldn't open, and had it replaced under warranty. It was almost two years ago, but I thought it was under $300.
  18. airborne spoon
    Ft Irwin
    From what i've seen in looking for parts, the last letter is a slight model change like new plastic or slightly different manufacturing changes but if the rest of the part number is the same it's the same part.
  19. airborne spoon
    Ft Irwin
    My door just had to get replaced it was $80 plus $110 in labor. but that was just the motorized door, the actual charge port costs about $650 plus labor as they wont sell it to you and they have to be the one to install it.
  20. KalJoMoS
    KalJoMoS Member
    EETN, EST
    You can look it up yourself, log in with your Tesla account settings:
    https://epc.tesla.com/#/login
