KublaConn
If you were an expert on roofs, you would have written the costs as per square, which = 100 sq ft as installed.
Thank you for the clarification as to the term used in the industry.
To my way of thinking, in this application, energy density - probably not the most correct term, but usable and understandable, is the least problematic of all the challenges:Isn't the energy density of Tuscan Tile a problem on most houses?
All true, but the lazy like me just use PVwatts.remember, it is the cosine of the angle of incident light, however the sun moves all day and rooftops are "fixed angle" (so far, but who knows, maybe someone will invent a flat, non moving tracker)
(trackers give appx 30% gain, or throw on a few more panels, back in time 40 years ago when PV was really expensive)
There are world Solar angle calculators. to give you an idea of roof/panels/etc.
my ~23 degree angle (rise of 5 in run of 12) is best for summer as I am at ~40 degrees N latitude
An easy rule of thumb for appx 40 degree north or south latitude is subtract ~15 for an optimal tilt of around ~25 degrees to max out summer gain
(the earth tilts +/- ~23.5 degrees effectively as it goes around the sun or around ~47 degrees)
(there are LOTS of books and info over the last 40-50 years)
Solar Angle Calculator
No better insolation data available to Joe Homeowner, but it obviously does not know anything about your local shading.I find this tool to be a bit to optimistic ...
I've sometimes wondered if people realize that PVwatts gives insolation data upfront and then uses it to calculate PV production.The other thing nice about the tool is, like all tools, just that. One can always discount for shading, etc. It's a great starting point with a methodology one can dig into if they like.
Just saw the roof cost announcement, pretty cool. So he's committing to it being less than a normal roof. Seems like they plan to avoid breakage and they mention weight of shipping. I don't see how shipping the tesla roof will be cheaper but maybe compared to tile or slate.
Have you seen the SolarCity soft cost breakdowns? Not much prettier, though I certainly expect Elon to attack that first thing tomorrow.There are a ton of middlemen in roofing. Manufacturer, high margin sales organization, hugely overpaid sales contractors, contractors. It's a pretty f'ed up supply chain with a lot of waste. Typical roof is sold at 4x what it should be
I think you're right. That will be the Roadster to Model S ramp up of Tesla Roof.That's pretty clearly what they are comparing. The roofing types they showed like slate and tile already cost 5X+ asphalt shingles. That's what they mean about shipping costs and breakage. Neither are about asphalt shingles...slate and tile are delicate.
He's basically confirming they won't cost MORE than slate...which wasn't implied before when they seemed to subtract the energy savings to be competitive. If they can cost no more than slate or tile, have comparable looks and life and also generate electricity they will dominate the high end of the market.
