Costco tire rotation
hmmwv
216
121
Covington, WA
My local Costco will only fill my tires to the door jam number, in my case it's 45psi, earlier cars are 42psi. I asked them to lower it because I think 45psi cold is too rough, they won't do it. When on the freeway my tires are always at 50psi.
vickh
3,062
471
az
It's not a rough ride to me, but then again I prefer to feel the road.
i like to feel the road too, it's the potholes on the freeway I worry about. Our city does a good job paving local streets and they feel so smooth. This is why I wish they'd offer air suspension on the 3/Y. I might do an aftermarket option after warranty expires...
vickh
3,062
471
az
why not lower it yourself or go to DT they'll do it.
hmmwv
216
121
Covington, WA
I'm afraid I'll go too far and then unable to re-inflate it back up, I suppose I can go to DT but my local one always has a line even for inflating tires. I wonder if there are tire pressure gauges that can deflate tire while monitoring pressure.
Feb 17, 2019
239
336
Houston
Nitrogen isn't harmful, but it provide absolutely zero benefit too.
I honestly never take the free samples. It just seems sad. The pizza isn't bad, but my guilty pleasure is the hot dog with the deli mustard, relish, and onions.
The foot long all beef hot dog is where it's at. Buck fifty with a drink? Yes please.
Reactions: XLR82XS
XLR82XS
D M C
Jul 26, 2019
3,071
1,698
SWFL | Vegas
I dropped down in wheel size from the OEM 20" wheels to 18" Titan7 TS-5 wheels and called Costco in Elk Grove, CA to make sure they would install tires on wheels that are a different size than what's on the door jamb. The tire salesman/installer actually told me it was illegal to drop down in wheel size. He said it's okay to go up in wheel size, but illegal to go down in size. After he said that, I didn't want them touching my car and went to America's Tires across the street. In and out in about 35 minutes and they have their own set of jack pad adapters.
ILLEGAL!? That guy's crazy...
OCR1
3,739
4,085
Southern California
AlanSqB
Dog Chauffeur
Mar 20, 2015
672
1,023
Gig Harbor, WA
You can get a pneumatic tire inflator. They're much less expensive, easy to use and maybe one day you'll get a small compressor so you can fill and empty your tires. :)
I use this type because it's trigger to fill, thumb button to empty. I can get a very accurate fill very quickly. It also clamps on the valve so I don't have to fuss with holding it on.
Pistol Grip Tire Inflator with Dial Gauge
Sophias_dad
911
765
Massachusetts
Reactions: AlanSqB
CharleyBC
1,380
1,551
Talent, OR
You might want to consider something like this anyway: https://smile.amazon.com/gp/product/B01L9WSTEG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1. Since the 3 has no spare, suppose you're on the road and get a slow leak, like from a nail puncture. With a pump, you can inflate the tire every 10 miles (or whatever) until you get someplace to have it fixed. I bought this as anti-stranding insurance. It's also, "oops--I let out too much air" insurance. ;)
Works great on bikes too!
OCR1
3,739
4,085
Southern California
I bought that one initially from Amazon and it blew a fuse on both of my Model 3’s. I know others have said it seemed to work fine so I’m not sure why I had no luck with it. My 20 year old pump that has never failed also blew a fuse on both Model 3’s. From that experience I’ve learned to stay away from things that require being plugged in to the cigarette adapter.
CharleyBC
1,380
1,551
Talent, OR
Hmm. Never had a problem. I've used it on both our car and our son's Model 3. (And my father-in-law's Subaru.) Thanks for making me nervous! :oops:
CAAD
202
63
NorCal, Bay Area
America’s tire rotated tires for free but I added balancing all 4 tires original oem 20”. Never knew they were so off. Its much smoother now. They use Hunter balancers.
CAAD
202
63
NorCal, Bay Area
$60 lifetime + rotation. I then took my suv in for the same at a different store and they did it for free.
I suspect it was free on good will because I talked to them about replacements.
OCR1
3,739
4,085
Southern California
Interesting. My $26.99 price at Costco included both rotation and balancing. So it would take three visits to AT to make that a better deal than the Costco price. But I’m guessing that I may only need two rotations on the OEM tires before they wear out. After that if I buy the replacement tires at Costco the rotation and balancing would be free.
So the “free” offer at AT is not quite as good of a deal as it first sounded to be.
