Couples of 1/4mile runs with my 85D
Discussion in 'Video' started by llavalle, Apr 20, 2015.
Tags:
  1. llavalle
    llavalle Member
    Somewhere around Montreal in Quebec, Canada
    #1 llavalle, Apr 20, 2015
    I posted this elsewhere (85D new sport mode) but here it is again, just because ;)
    2015 85D v2.4.153 (6.2 Sport mode)
    Michelin MXM4 OEM Tires @ 50PSI
    Ext Temp : 10C/50F
    First run : 62% SOC
    Last run : 54% SOC
  2. bhzmark
    bhzmark Active Member
    What are the times? Pls post in text
  3. Stoneymonster
    Stoneymonster Active Member
    Aptos, Ca
    I really want to see this at high SOC :smile:
  4. AWDtsla
    AWDtsla Active Member
    NE
    Are those your tires squealing or the next lane?
  5. InternetDude
    InternetDude Member
    Yes
    Three 12.7 second times and one 12.8 time.
  6. clarkbariowa
    clarkbariowa Member
    Elgin IL
  7. llavalle
    llavalle Member
    I wanted to go there tomorrow night but weather forecast call for rain so it probably won't happen.
    Front tires squealing. This track is on concrete (airport runway) instead of regular pavement (asphalt) so it's a bit less "grippy" and there was a lot of rubber on the track. Since this was a "street drag night" ($10 to get in, as many run as you like) - no glue on the track.
    Under full acceleration the 85D has much of its weight in the back and since both motor have similar output, the rear one cannot "push" the car forward enough - hence tire slip in the front. The P85D does not have this problem. The rear motor can keep up ;)
    On the first run, I was alone. 2nd Run was with a passenger against a old Lancer with an EVO Swap. 3rd one against a FJ Cruiser and last one against a Chevy 2500 HD (the guy in my car on the 2nd run)
    - - - Updated - - -
    #1 62%SOC: [email protected] (lifted the accelerator 100ft from the end - my first time at this drag strip)
    #2 59%SOC: 12.7?? (timer error)
    #3 57%SOC: [email protected]?? (printer error, no slip)
    #4 54%SOC: [email protected]
  8. llavalle
    llavalle Member
    #8 llavalle, May 8, 2015
    I went again last night with a friend who owns a SL65 AMG (Twin Turbo V12)
    This time I was at 89%SOC for the 1st run and 86% for the second one. I had a passenger both times and around 80lbs of stuff in the frunk. (last time I emptied the frunk)
    Exterior temp was around 72F and elevation 270' above sea level.
    #1 : [email protected]
    #2 : [email protected]
    Next time I'll empty the frunk and try without a passenger.. I hope to see a 12.5XX :)
  9. fiksegts
    fiksegts Active Member
    Miami
    thanks for posting, never run with a passenger, slowing you down for sure... :)
    can you post up the timeslips so we can see all of the data?
