Allow me to go down in flames once again on the fault with using this "ROI" concept, which in solar land means at what point is the system "free" to the adopter to the extent that total purchase price is paid off by that time with what would have been the actual payments to the utility.
Its needlessly complicated and I believe it was cooked up by solar sales guys. It sounds so great to say, "and it will pay for itself in X years."
The point is, especially with the utilities trying to add non bypassable monthly charges, that I believe its better to do this in the traditional financial way, that all you need to do is calclulate (a) your average bill, and (b) the monthly cost of your system by assuming you finance the system over 20 years (its warranty life) at whatever the rate is now (mine was 5%). You can either satisfy your monthly energy needs by buying it from source one, the utility, or by producing it yourself.
So (b) is less than (a). Every month, year in, year out. As rates rise, but your financial obligation does not, (b) actually becomes more of a monthly savings.
Its also easier to add in ESS. With my 16.32 and 3 powerwalls, I am at a savings of a bit more than $250 a month. I would save more per month without the ESS becuase LADWP does not have a brutal NEM calculation. For people trying to calculate rate arbitrage (where ESS saves super peak rates vs. the credit you get with solar only), I mean, life's too short, eh?
I am grandfathered in, but if I was a prospective buyer and they added the $8 per installed kw charge it would be a very, very small savings per month, maybe down to like $40?
And they could sop up that $40 by messing with the credit calculation.
No, with the proposals now being discussed there is no "rate of return" at all, and I did not see, although I could be wrong, an exception for solar plus ESS.
I am sure the solar industry knows this, which is why they will fight to the end. But this concept, incredibly now used by all the major players of "a reasonable ROI" measured in years, is driving me crazy.
The actual "ROI" is that my system produces X amount of electricity which I would normally have to pay Y dollars for at a cost of only Z dollars. The delta, since it is measured in dollars, then shows what is going on.
I paid $50K (rounded) for a system that produces about $3k per year in return (about $200-$250 ish a month, rounded) so my rate of return is 6%.
That's why people are adopting solar. Six percent is not bad.
If you drop the benefit down to $40 a month its down to like 1%. That's why ten years ago solar was not as popular.
OK, I will try to give up now.
PS, OK, F-me. Yes, the solar land "ROI" sort of works if you figure out the system you get is truly depreciable in that at some point it wears out. Yes, ok, that's relevant, to say, "you are buying a system that will be good for 20 years but will pay for itself in 5 years." See, that's not a lie but its why the sales people use it. In my system, maybe I have to replace the entire thing in 20 years, but so what, at that point you do the same calculation. Or, the system actually lasts for 25 years. Or, you just upgrade the panels only at a much cheaper cost than a new install. Time will tell.
