CR says no EV can go more than 400km/charge
Discussion in 'Model S: Battery & Charging' started by TLej, Jul 29, 2018.
  1. TLej
    TLej Little-Known Member
    Edmonton, Alberta, Canada
    0812CA04-45E7-42DD-BCE4-D90B16352FC4.png Just doing the summer survey for CR this morning, this is one of the survey questions. I would have thought they’d be a little more up to date on the state-of-the-art; under-reporting my 90D by 30km is one thing, but what if I had a 100D?
    C’mon, CR, time to get with the program.
    • Informative x 2
  2. jerry33
    Texas
    Normal for CR. They are generally full of it.
  3. Rockster
    Rockster Active Member
    McKinney, TX
    For me, the bloom fell off the CR rose many years ago...
  4. Yggdrasill
    Yggdrasill Active Member
    Kongsberg, Norway
    I have an average consumption of 232 Wh/km on my X100D after 46k km, so that's an average range of ~422 km. I'd guess an S100D would be around 217 Wh/km or 452 km.
    So, yes, the range should have been broader, but extending it to 500 should be enough.
  5. ChadS
    ChadS Last tank of gas: March 2009
    Redmond, WA
    That does suck, but when I filled it out in miles, I was able to put in a larger number. So perhaps the survey designer specified the parameters properly, but a web developer did the unit conversion incorrectly.
