Cracked pano roof mystery...
Discussion in 'Model S' started by Caligula, Sep 22, 2016.
Tags:
  1. Caligula
    Caligula Member
    San Diego
    So I just noticed that my panoramic roof has a giant crack in it. Upon closer inspection, I cant find any impact damage from anything nor can I recall any event which would cause this. Im wondering at this point if its a defect in the glass? Take a took and tell me what you think.
  2. Caligula
    Caligula Member
    San Diego
  3. Caligula
    Caligula Member
    San Diego
  4. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    Looks like the leading edge, right? Probably a tiny stone hit it just right. This type of glass is very susceptible to impact damage on its edges.
    I had a crack on the windshield with no eye-visible impact damage, but if you used a fine ballpoint pen you could actually find the source. Even knowing where it came from, I still couldn't see it from up close. Might be hard in this case if it's that edge, though. Not sure the pen trick works on edges.
    That said, it being some kind of defect isn't unheard of.
  5. Caligula
    Caligula Member
    San Diego
    Which makes me wonder if Tesla will cover this under warranty...
  6. Gizmotoy
    Bay Area, CA
    Certainly you should ask. Tesla actually covered that crack I mentioned in the previous post as a Goodwill item because it occurred right where spontaneous cracks were forming in early Model S, so despite mine not being affected, it was a known weak point in the glass.
    Worst case, they find it's a chip and you have to pay... which you'd be doing anyway.
  7. sorka
    sorka Well-Known Member
    Merced, CA
    If you're adjuster is a glass expert, they will be able to tell if it was from an impact or a defect. If it's a defect, then Tesla would have to cover it if your car has less than 50K miles on it.
  8. BrokerDon
    BrokerDon Member
    Newport Coast, CA
    Cracks & chips in our cars and RV have been covered by our auto insurance under Comprehensive. I'm not sure if sunroofs are covered too but probably worth a call to your insurance agent / insurer.
  9. Neohippy
    Neohippy Member
    Florida
    I wonder how much that would be to replace? Sorry to see this.
  10. Caligula
    Caligula Member
    San Diego
    Spoke to my SvC, and they suggested bringing it in for an inspection. Any reason to have my adjuster look at it prior to this?
  11. habanero69
    habanero69 I Dont Need Cialis. I Drive an EV.
    FLorida
    Did you tint the roof? I cannot tell, but it looks like NOT. I was told by the guy I had tint my car that he would NOT do the roof. He had either been told or had experience/knowledge that this has led to cracks in some applications. NO, I do not have any link or direct proof, but it was what he told me, and since he wouldn't do it anyway, I moved on and didn't do the roof. :oops:
  12. Caligula
    Caligula Member
    San Diego
    There is no had has never been aftermarket tint on the pano. Ive never felt the need for it even in the middle of a 100° So Cal summer.
    Also the SvC has an appointment for 2 weeks out at the soonest. I hope this doesnt get much worse.
  13. Lawsteve
    Lawsteve MCATDT
    Tampa, FL
    I had a similar crack in my pano. Tiny chip at the beginning of the crack. Tesla did not offer to cover under warranty, but it was covered 100% by my comprehensive coverage for glass (required for all auto policies in Florida). You might want to go ahead and have your insurance company take a look. If they authorize replacement, you can use your appointment in two weeks to have the new panel installed.
    Good luck.
  14. BLKTSLA
    BLKTSLA Member
    Unknown
    My first Model S had the exact same thing happen seemingly overnight, looked like a stress fracture but no signs of impact from an object so the good folks at Tesla took care of it under warranty! I havent had the issue since nor with other Model S's, however, I would caution the speed that you may drive with the pano roof vented that IMO seems a likely cause for the glass to be stressed.
  15. Caligula
    Caligula Member
    San Diego
    This thought occurred to me today as well.
  16. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    #16 Lloyd, Sep 22, 2016
    Mine cracked when going into an uphill parking spot where the right front wheel went up first. Tesla inspected it an replaced it without question.
    Note that my crack is almost identical to yours!
  17. mknox
    mknox Well-Known Member
    Toronto, ON
    It seems Tesla has modified the pano roof over time. My early 2013's pano roof developed a bit of a shudder when it opened and closed and I asked Service to "grease it" while it was in for something else. Well, they had the car for a week and basically re-built the pano roof including new mechanicals and glass panels. My car is out of warranty and this was all done under "goodwill". I was shocked (pleasantly) that they would go to these measures to fix a mild shudder, and they told me the design of both the glass and the mechanism has evolved over time.
