Cracked Rotor - Brand New. How?
kirkhilles
2014 Model S w/ AP1
May 3, 2019
68
36
Northwest Georgia
I just finished redoing my front brakes (new rotors + pads + brake fluid) and I started to work on my suspension and noticed my new rotor was cracked. GRRRR.
Could someone please tell me what likely happened and whether this is a manufacturing defect or something I did incorrectly. I guess I know the answer on whether it needs to be replaced.
I ordered the rotor from RockAuto and believe that I ordered the correct one: CENTRIC 12052002. This is the front right rotor.
Thoughts?
GeorgeM
47
68
NJ, USA
Not 100% certain, but from how it appears in the picture something was trapped between the hub and the rotor. All the cracks radiate outward from one point and the cracks are wider at that "center" point. Entirely possible the rotor was machined incorrectly but more likely some small foreign object got trapped. I am assuming this was noticed after the wheels had been reinstalled, the lug nuts torqued and pressure applied pushing the rotor against the hub. Now that I look closer at the picture the wheels had to have been installed as there are marks from the wheel on the rotor and the crack is into a void in the wheel casting. Something was under that rotor.
TonyT
839
684
Orange county, CA
The new rotor should have a hole for the bolt, if there is one sheared off on the hub, future install of new rotor aligning to the hole should prevent damage. The screw helps hold the rotor in place when calipers are removed. Be careful of the rotor falling off in that condition.
