"Crackling" noise in headliner aft of the Driver sun visor
Discussion in 'Model S: Interior & Exterior' started by 4us2bev, May 15, 2015.
  1. 4us2bev
    4us2bev Member
    Los Altos, CA
    P85D, noticed going over rough roads that I was getting some noise/vibration above my head.
    With the car stopped, if I unfold the driver sun visor and push gently aft of the visor on the headliner, I get a slight cracking sound. Doesn't happen on the passenger side.
    Any ideas? Perhaps the headliner does not have good adhesion to the sunroof area?
    Thanks!
    -- David
  2. pgiralt
    pgiralt Supporting Member
    Cary, NC
  3. 4us2bev
    4us2bev Member
    Los Altos, CA
  4. pgiralt
    Cary, NC
    That's very similar to the issue I had. The service center was able to fix it. Had something to do with whatever it is they use to hold the headliner on.
  5. 4us2bev
    4us2bev Member
    Los Altos, CA
    Thanks, glad it's not just me. Out of curiosity were you hearing the noise while driving on bumpy roads, as well?
    -- David
  6. chriSharek
    chriSharek Member
    Sarasota, FL
    If you had the Pano roof, you wouldn't have this issue! :)
  7. pgiralt
    Cary, NC
    Yes, I was. For the longest time I thought it was something wrong with the pano roof because for me the sound was coming from the passenger side between the front and back doors and the service center could never figure it out. The one day I pressed on the headliner and discovered that's where the problem was.
    - - - Updated - - -
    I have the pano roof and still had the problem.
  8. Keystone S
    Keystone S Member
    Greater Philadelphia
    I had this issue a about a year after ownership. Whenever driving over a bump, I would get a rattle. Seemed to be coming from passenger side somewhere either above the headliner or in the dash. I had it checked at a service center and they said it was the radio antenna (AM I think) which had become dislodged. They re-glued it (or refastened it in some way and that solved the rattle. It's been good ever since.
