crazy swiss drive going where no electric car was before....
Discussion in 'Roadster' started by Mitrovic, Aug 10, 2011.
Tags:
  1. Mitrovic
    Mitrovic Member
    Bern, Switzerland
    Well, not really, but it sounds good, isn't it?
    Yesterday I was invited to drive the "Alpenbrevet 2011". A night drive over around 14 alp passes and 900 Kilometer. Expected time: 20 hours.
    50 cars, mainly oldtimers and one Tesla! Starting in two days at full moon!
    Sounds impossible, and it is without proper preparation! It might be possible with a HPC on the right place, but like that I will do a shortened version. Between 600 and 800 Km with a charging stop of about 4 hours at 32 A ( and getting some sleep, too ).
    Now I have to do the maths! I wil start hopefully fully loaded. The start is some 100 kilometers from my place and I'll have to work in the morning.
  2. Eberhard
    Eberhard #421 Model S #S32
    Germany
    you can travel 350km on first charge, 4h on 32A give you another 150km. Total 500km. even with an HPC quite impossible to do the whole distance within 20h. you have to charge 2 times.
  3. Mitrovic
    Mitrovic Member
    Bern, Switzerland
    My plan is to go 200 Km, then charge with 32 for 90 minutes, gives me about 70 Km, then go 200 Km charge for 4 hours give me 150 to 200 Km Km then go for 200 Km and charge for 90 minutes with 32 A gives me about 70 Km.
    That gives me: 400 + 70 + 200 +70 = 740 KM
    Charging time: 7 hours
    Driving time: 13 hours
    And as I will drive the shortened version, this should be o.k. Well theoretically....
  4. Eberhard
    Germany
    dont forget to charge in performance mode to get most mileage from the input. i get only 40km ideal range on 32A and 120% real range compared to ideal range
  5. Mitrovic
    Mitrovic Member
    Bern, Switzerland
    Thank you for your advice, but I did not understand the numbers?
    So you would say to charge in performance mode, but to drive in range mode?
  6. Eberhard
    Germany
    yes - charging in performance will allow higher temperature in the pack without or little cooling. If I run carefully in range mode, in can get 20% more range then Ideal range with consumption below 130Wh/km. Try to avoid excessive acceleration with high current consumption or fast uphill pace. Try to stay below 50A, even uphill.
  7. S-2000 Roadster
    I look forward to a trip report! Take careful notes of charging modes, current, times, mileage, etc. Also, you can probably pull your VehicleLogs when you're done to get most of these numbers (everything but estimated ideal miles for each leg).
  8. Mitrovic
    Mitrovic Member
    Bern, Switzerland
  9. Mitrovic
    Mitrovic Member
    Bern, Switzerland
    I f you would like to look at the map.
    The plan is:
    Start at 16.00 in Meiringen, fully charged. Sustenpass ( 2244m ), Andermatt, Oberalppass ( 2044m ), Disentis, Lukmanierpass ( 1914m ), Biasca, St. Bernardino Pass ( 2065m ), Splügen, Splügenpass ( 2113m ). Arriving at 22.00 in Motespluga for a dinner and may be a little recharge, if I find a socket!? So far around 260 Km.
    Then Chiavena, Malojapass ( 1815 ), St. Moritz. Hope to arrive at around 0.30. Some 77 Km. Total 337. The EV friendly station St. Moritz should have installed a 32 A socket for the car and a nice room for me. Loading for about 4 hours.
    Departing at around 5.00 to Julierpass ( 2284 ), Tiefencastel, Airolo, Sankt Gotthard Pass ( 2188 ), Furkapass ( 2481m ), Grimselpass ( 2165m ). Charging for 90 minutes with 32A and taking a breakfast. Meiringen, and the finish in Interlaken. Around 322 Km. Hope to arrive at around 14.00.
    Then some more 80 Km to get home!
    So, the run will have a total of about 657 Km. With the way to the start and from the finish, it will be around 830 Km! 10 Swiss alps crossings! The highest being Furka at 2481 m above sea.
  10. Eberhard
    Germany
    sounds to be a nice trip. Maybe some Roadster should do this trip at daytime and on 3 days (nights for recharging). Any Owners out there to join for a ride together? or on 2 days? with some charging around noon? saturday/sunday?
  11. Mitrovic
    Mitrovic Member
    Bern, Switzerland
    so far so good.
    330 Km - 6 Alp crossings - 5,5 hours.
    Now Floating with 32A
  12. Eberhard
    Germany
  13. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Could you explain this advice again? From what I've heard, for the absolute maximum range you should charge in Range mode, and then hit Top Up several times.
  14. Mitrovic
    Mitrovic Member
    Bern, Switzerland
    Back at home! Car is charging and I'm recovering. I'll try to post the full story soon. But here the results of stage two:
    St. Moritz - Julierpass - Tiefencastel - San Bernardino ( tunnel - the pass I did on stage one ) - Gotthardpass - Furkapass - Grimselpass - Interlaken - Bern - Murten:
  15. Eberhard
    Germany
    ahh, your consumptions was even lower then my personal record. i only did 420km with 51kWh = 121Wh/km
  16. AndrewBissell
    AndrewBissell Member
    189 Wh/mile is exceptional!
  17. Eberhard
    Germany
    While charging in performance mode, the cooling is less, therefore, less power is directed to AC and more power is left for charging.
  18. S-2000 Roadster
    #18 S-2000 Roadster, Aug 13, 2011
    So, what you're saying is that Performance is the fastest way to charge, even if Range gives the most charge. If you do not have time to spare and are willing to accept slightly lower charge, then use Performance. If you absolutely must get the maximum charge and have the time, then use Range. For such a trip as described in this thread, I suppose you'd start out with a Range charge at home, then Performance charge along the way, followed by Standard charge upon returning home.
  19. Mitrovic
    Mitrovic Member
    Bern, Switzerland
    Eberhard thank you I did as you told and charged in Performance mode and did drive in Range mode.
    I'm preparing a small article I will post here with the details, it might get published, too.
  20. Eberhard
    Germany
    What about doing the trip on daytime, together with other Roadster?
