Creaks and Groans While Turning
Discussion in 'Model X: Interior & Exterior' started by Pandamoanium, Jul 16, 2018.
  1. Pandamoanium
    Pandamoanium Member
    Colorado
    How many of y’all have an X that creaks and groans like things are going to snap while turning? With the summer temps, I’ve noticed it becoming worse and usually the middle console pairs with front seats. Just want to know if it’s an issue for others as well.
  2. P85_DA
    P85_DA Supporting Member
    Mine does occasionally but nothing I’m too concerned about this is a heavy car :(
    • Disagree x 1
  3. Brian's ReX
    Brian's ReX Member
    Seattle
    Ditto @P85_DA
    However, "groans like things are going to snap" is a bit alarming. Mine is only noticeable if climate and music are off (sometimes I just like to hear the 'nothingness' that Tesla emits as opposed to an ICE)... and even then, it's only small creaks.
    If it's that dramatic, it may be worth mentioning on your next trip to a SC, if needed.
  4. pdx3181
    pdx3181 Member
    Portland, OR
    I have an odd sound on the left edge of my windshield. It sounds like someone is using a guitar pick on an really over-tight guitar string. It's a *tick* or *snick* if you will.
    There's been no change since I bought it - so I am not worried about it.
  5. Brian's ReX
    Brian's ReX Member
    Seattle
    @pdx3181: Maybe keep an eye on water intrusion? By no means am I an expert, but maybe it's the windscreen 'adhesive' that's come almost undone? Thinking about a pane of glass coming in contact with a very sticky substance, then being 'pulled' off - makes me think of the "tick/snick" you mention.
    Just a thought...
  6. Pandamoanium
    Pandamoanium Member
    Colorado
    I’ll have to do it when I have time to ride with a tech. First time they said they heard nothing, mobile unit came out to install 22” wheels and she took it for a spin. Literally one minute to circle and she heard everything. We were both confused as to how no one heard anything.
    Luckily she corrected the seat sounds with another tech. The other stuff would need a SC visit. I’m sure I’ll bring it up eventually, my visits to the SC haven’t been positive.
  7. jboy210
    jboy210 Supporting Member
    Northern California
    Try gummi pflege on the rubber seals on the doors or plastic joints you hear the creaking. One of my BMWs creak on every turn and every time you go up the driveway. With gummi pflege most of those noises go away.
  8. zackmilo
    zackmilo Professional moron
    Westwood, Los Angeles, CA
    Service replaced something in my suspension under warranty. Sound is gone.
  9. Pandamoanium
    Pandamoanium Member
    Colorado
    Mine is 100% inside the cabin.
  10. lloyds
    lloyds Active Member
    Bay Area
    I too have noticed, but I also wonder if it's because there is no engine and transmission noise on my Teslas compared to ICEs
  11. Pandamoanium
    Pandamoanium Member
    Colorado
    I don't think so. I've had a few ICE vehicles and they normally will address them. Temperature fluctuations will cause them to come and go, but the ones I have are persistent regardless of temp. It'll just make it worse or less. It could be the parts and how it's assembled, though I have not taken a ride in a newer model so it could just be something I'll need to live with.
  12. bionichomer
    bionichomer Member
    Atlanta
    Raising the dead here... Did you ever get the seat noise fixed? Did they say what was fixed? My 2016 X has noise on passenger front seat. Creaks badly. Service center added more padding but that didn't help. The noise is evident when a passenger sits in the seat while I drive and make any turns. To recreate the sound while sitting in the driver's seat, if I push on the side of the passenger side headrest, I hear creaking near the seat belt (by the center console) on the passenger seat.
  13. Pandamoanium
    Pandamoanium Member
    Colorado
    For me it was semi fixed by greasing the rub points between the passenger seat and middle console area. Drivers seat was bolted down again and it went away for a little but is now back with a persistent rattle/squeak anytime the car is in movement. I plan to bring it up to Tesla again, just not sure when.
